292 engine numbers
Old Jul 25, 2005 | 03:30 PM
mattey's Avatar
mattey
Smile 292 engine numbers
I've just got my 63 F100 back from the docks & have to register it, sounds sort of dumb but where are the numbers stamped on the engine? Also the location of the vin number.Under the hood is so caked up with oil & dust I could be searching for days , thanks for your help mattey
Old Jul 26, 2005 | 11:30 PM
rogerf100's Avatar
rogerf100
You should be able to find the truck rating plate with the info you need. It will be located inside the cab. Try looking on the inside of the glove box door and on the door post. The Warranty Number is the serial number or VIN. The serial number is stamped on the frame and body, but my manual does not show where those locations are.
e250blex
Apr 8, 2015 07:21 PM
Micbruff
23
Nov 5, 2014 08:17 PM
Scott1965FordF100
Aug 20, 2014 02:20 PM
hobbyhorst
Flathead V8 & Flathead 6
Jun 3, 2009 05:06 PM
