another 460 swap question
Old Nov 21, 2002 | 04:26 PM
Umpqua Arms's Avatar
Umpqua Arms
Im sure this has been asked a hundred times but is it true that 390 car mounts can be used to swap in a 429/460 in a truck that had a 400m previously by using the left on the right and vice versa? Also i understand that the older 429s will outdo a 460 performance wise. What is a fair price for a 68 429 that supposedly ran when pulled but probably needs a seal kit or something since it has sat for a while undercover. Thanks
Old Nov 24, 2002 | 02:12 PM
fordlowboy's Avatar
fordlowboy
hi
i can't tell you about the motor mounts but, the nengine depending on how bad you want it is worth between $200-$800. Me personally i'd only 350 max.
Old Nov 24, 2002 | 02:40 PM
Ford_Six's Avatar
Ford_Six
