Radio Wirering
Old Jul 25, 2005 | 10:24 AM
F250Wheels's Avatar
F250Wheels
Radio Wirering
I Have An 1999 Ranger, I'm Installing A Jvc Cd Plaver. Any Body Have A Wiring Diagram And Could Tell Me The Color Code On The Factory Radio Plug.
Thanks
Old Jul 25, 2005 | 10:51 AM
rangerxlt02's Avatar
rangerxlt02
Hey F250, why not get a plugin to wire to your JVC head unit? Wally World or any Automative Audio Shop should carry one on the shelf. That way you don't have to cut the wiring.
If you really need a wiring diag, try here: http://www.installdr.com/
HTH
Old Jul 25, 2005 | 12:35 PM
redranger98's Avatar
redranger98
I recommend buying the harness from your local automotive as well. I just changed the stock radio to a Pioneer head. The change was easy and you can do all the wiring to the new head out of the truck, then plug and play. Good luck. BTW The part here in NY cost me $17.
Old Jul 25, 2005 | 12:49 PM
jinx102672's Avatar
jinx102672
Thumbs up
I agree. Go get yourself a adapter harness. It will save you time and if something should ever go wrong with your new unit (hopefully under warranty), or if you don't like it, it will be much easier to replace.
Old Jul 25, 2005 | 01:11 PM
gopher18's Avatar
gopher18
From Another Site:
Wiring Colors
Radio power and lighting
# 12V constant = lt. green/purple
# GROUND = black
# 12V hot in run = yellow/black
# lamp/dimmer = lt. blue/red
Speakers
# LF SPEAKER: (+) = org/lt grn, (-) = lt blu/white
# RF SPEAKER: (+) = wht/lt grn, (-) = grn/org
# LR SPEAKER: (+) = gry/lt blu, (-) = tan/yel
# RR SPEAKER: (+) = org/red, (-) = brn/pnk
| 12V|yellow |+ |ignition harness |
| STARTER|red/lt. blue |+ |ignition harness |
| IGNITION|lt. green/purple |+ |ignition harness |
| ACCESSORY|gray/yellow |+ |ignition harness |
| SECOND ACCESSORY|black/lt. green |+ |ignition harness |
| POWER LOCK|pink/yellow |- |driver door harness or PKP|
| POWER UNLOCK|pink/lt. green *4 |- |driver door harness or PKP|
| LOCK MOTOR|pink/black | |driver door harness|
| UNLOCK MOTOR|red/orange | |driver door harness|
| DISARM DEFEAT|pink/orange | |passenger kick panel|
| PARKING LIGHTS +|brown | |headlight switch or GEM *1|
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|*2 |- |GEM *1 |
| DOME SUPERVISION|use door trigger | |
| FCTRY ALARM ARM| | |
|FCTRY ALRM DISARM| | |
| TACHOMETER|tan/yellow | |instrument cluster or PCM *3
| SPEED SENSE|gray/black | |GEM *1 |
| BRAKE WIRE|lt. green |+ |brake pedal switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|wht (L), blu/org (H)|+ |windshield wiper motor |
| LF WINDOW UP/DN|wht/blk - red |A |driver window motor |
| RF WINDOW UP/DN|wht/yel - tan/lt blu|A |driver door harness or PKP|
| RADIO 12V|lt. green/purple |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/black |+ |radio |
| RADIO ILLUMINATE|lt. blue/red(dimmer)|+ |radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |radio |
| RF SPEAKER|wht/lt grn - grn/org| |radio |
| LR SPEAKER|gry/lt blu - tan/yel| |radio |
| RR SPEAKER|org/red - brn/pnk | |radio |
NOTE: This vehicle is equipped with PATS (Passive Anti-Theft System). . *1 The GEM (Generic Electronic Module) is to the left of the radio. *2 The driver door trigger is yellow/black and the passenger door(s) is gray/red. Use both wires and diode isolate as shown in directfax document #1076. *3 The PCM (Powertrain Control Module) is on the top of the firewall under the hood towards the passenger side. The tachometer wire is in pin 48. Can also get tach at the ignition coil or coil pack. Use any of the tan/stripe wires. *4 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to "wake-up" the system
Originally posted by Matt Mason (Straightedge from G-E.COM)
Old Jul 25, 2005 | 01:28 PM
F250Wheels's Avatar
F250Wheels
Thanks Gopher 18.
I Looked For A Plug In Adapter Plug, Couldn't Find The Right One, Figired I Just Cut And Spice And Be Done With It.
