Air Cleaner Inlet
Old Jul 25, 2005 | 09:28 AM
misty24's Avatar
misty24
Air Cleaner Inlet
Does anyone know if the tube coming off the air cleaner comes apart? I'm polishing my air cleaner and I want to paint the tube because it's rusted. I'd like to take the two halves apart so I could treat the inside with a rust inhibitor, but I'm not sure how easily it comes apart.
Old Jul 25, 2005 | 09:32 AM
Zod's Avatar
Zod
It's usually just riveted on with two pop-rivets. Use an 1/8th " drill and drill the centers of the rivets out, pull the rivet shells from the holes, and then pull the lnlet tube off. You can either pop-rivet the lnlet back on, or use bolts and nuts to put it back on.
