Supercharger Installed
Old Aug 18, 2005 | 12:07 PM
STX03F150's Avatar
STX03F150
Originally Posted by Evil Red Genius
I have a question about the Wynjammer supercharger kit. I looked up the website and saw what the actual supercharger looks like. It looks as if there is no reduction gear box on it. That being said, I am wondering how many RPMs it spins at? Does it spin at the same RPMs as the engine? I am currently converting a GM turbocharger in to a similar part. I took off the exhaust side of the turbo and am going to add a pulley on the other side. I am trying to figure out if it will spin fast enough to generate enough boost and how much? Please, if somebody has insight on this, please let me know.
here a place i found that has similar projects, they take turbos and convert them into superchargers. http://www.gatorsuperchargers.net/photos/photos.htm check it out they have a lot of info on their projects. lots of good info.
Old Aug 19, 2005 | 05:09 AM
My98FordF150's Avatar
My98FordF150
Gator Superchargers
That's a pretty fascinating concept. I'd love to see the results on a 4.2.
Old Aug 21, 2005 | 07:05 AM
My98FordF150
Dyno Numbers
My best dyno was 253 HP and 304 torque; however, I had them graph it with the STD HP/Torque option which I understand is less accurate than SAE. I'm going back on Thursday for a second dyno session. I'll ask them to do a SAE graph next time. I'll attach the graph once I figure how to.
Old Sep 4, 2005 | 09:40 PM
TheFordManiac's Avatar
TheFordManiac
where??
where did you find a supercharger for the 4.2? i've been looking all over and cannot find one! please tell me where you found it! lol
Old Sep 5, 2005 | 09:38 AM
My98FordF150
Supercharge Installed
I bought the kit from another site member. He originally purchased the kit from the following company:
Need For Speed
1936-A Sherwood Street
Clearwater Florida 33765
727-539-7733
My final dyno numbers are 280 RWHP and 316 rear wheel torgue.
Old Sep 5, 2005 | 12:33 PM
TheFordManiac
thanks
wow thanks, btw great numbers , but what was the brand of the supercharger?
Old Sep 5, 2005 | 12:40 PM
TheFordManiac
found it
nevermind i found the 4.2 f150 performance corner, thanks for the help.
Old Oct 15, 2005 | 09:50 PM
fordnissanpower's Avatar
fordnissanpower
thats pretty good
Old Oct 16, 2005 | 01:18 AM
Evil Red Genius's Avatar
Evil Red Genius
Hi all. Ive been away for a while. Ive made a change to my twin supercharger idea. Im only running a single. Im almost complete with the supercharger. I am using a planetary gear box from a warn winch and running it in reverse and using only the first stage. Im still curious how it will turn out. If my math is correct just the first stage planetary should spin the impeller at a rediculous speed. I guess well have to see what happens. Stay tuned for more.
ERG
Old Oct 22, 2005 | 07:39 AM
My98FordF150
Twin Supercharger
That will be an awesome setup. Are you planning on installing stronger internal parts?
Old Oct 22, 2005 | 01:09 PM
rmanTX's Avatar
rmanTX
i wonder if it'll be enough to take a mustang cobra past 2nd gear......
j/k haha
Old Oct 23, 2005 | 08:27 AM
My98FordF150
It's possible, but a Ford Cobra puts out 390 HP and 390 torque at the flywheel. If you managed to beat a Cobra, I'd pay money to see the look on the driver's face.
Old Oct 26, 2005 | 08:32 PM
  #28
Evil Red Genius
Well, Im a little edgy as far as using the gear drive. It seems to work the way I expect it to, but its a little choppy, but that could be because nothing is completley connected yet. I also decided on an optional reduction gear box utilizing a 5" pulley and an 1 and 1/2" pulley. If this works the way I hope, it should spin anywhere between 20-and 50000 rpms. The bonus to that is its way cheaper to replace the belt and it uses ball bearings for smoothness and an open gear box for cooling. I saw a similar design on the gator supercharger setup. Either way I will still save the planetary gearbox for possible switch or other superchargers. Hey check out my album, I added more pictures. Till soon.
ERG
Old Oct 26, 2005 | 08:35 PM
  #29
Evil Red Genius
Oh, by the way, the 390 HP you mention is a conservitive figure given by the factory. I know for a fact that a 2003 Cobra will put out over 410 HP on the dyno un modified. I saw it almost four years ago. Sorry didnt want to step on your tail.
ERG
Old Nov 6, 2005 | 05:50 PM
  #30
TboneThom's Avatar
TboneThom
to all you guys and girls out there who want to add a supercharger to your 4.2l you better do some internal work to your motor as well oh dont add a superccharger to a motor with alot of miles on it and it better be in good running condition for starters you will need a higher capacity fuel pump 255lph is a great start headres a re a must a camshaft is also a must a bigger throttle body a bonus and you better add at least 24#hr if not 30#hr fuel injectors a mass air meter for the extra air delivery 85mm works great and a flash burner to calibrate your fuel curve you mass air meter and your fuel injectors ill give you the names of the manufacturers also to help you all out
jba makes the headers fordmotorsports makes the injectors need for speed has the supercharger kit bbk had the throttle body and fuel pump rpm_mustangs has the camshaft and rollerrockers sctflash has the flash burner and you better use a copper cored spark plug with around .35 to .45 air gap any other questions just post one
