Serpentine Belt Issues
Old Jul 24, 2005 | 12:36 PM
RabbitRa's Avatar
RabbitRa
I am trying to install a Serpentine belt on a 93 Econoline. The New belt and the old belt are the same Manufacturer and have the same part number however, the New belt seems to be a good 4 inches shorter than the old belt. I figured this was due to the Old belt stretching and continued.
I removed the Old belt by lifting the Tensioner in the counterclockwise direction as listed on the Decal noting the pathing of the old belt. Now is where I run into issues. I am trying to get the new belt in place but even with the tensioner completely lifted the new belt is still quite a bit too short to make it over all the pulleys.
Any ideas would be a great help.
Thanks
Bob
Old Jul 24, 2005 | 03:23 PM
Bluffer's Avatar
Bluffer
Check they way you routed it again, prolly got one pully wrapped backwards.
Old Jul 24, 2005 | 03:27 PM
FSC's Avatar
FSC
Did you note the path of the old belt or are you using the decal for belt routing? if the latter, be sure the belt is fully seated on the grooved pulleys, there is little room for error.
Old Jul 24, 2005 | 03:36 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome RabbitRa, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
