need advice Ebay head bolts....
Old Jul 24, 2005 | 12:01 PM
zsir's Avatar
zsir
Check these out...ebay item 7987633055 ..... I have a set...with the washers installed they are 1/4" shorter than OEM..... I'm not sure if washers are a good idea or not.....DSC sells head bolts with washers....what do you all think....???
Old Jul 24, 2005 | 08:18 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
OEM head bolts use washers and yes they are a good idea. I'd call Dennis at DSC to see how his compare to the OEM bolts. I see he has two kinds. ARP and another brand.
Old Jul 24, 2005 | 09:40 PM
zsir's Avatar
zsir
The motor I took apart didn't have washers on the head bolts....I didn't think FE's used washers....
Old Jul 25, 2005 | 04:04 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yep they do
Old Jul 25, 2005 | 07:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yep they do
Ain't never seen one with washers on the head bolts, but I've only had two 360's and two 390's, so what do I know?
Old Jul 25, 2005 | 02:43 PM
zsir's Avatar
zsir
I don't think they came with washers from Ford..........I'm not sure if I'm going to use them
Old Jul 25, 2005 | 03:01 PM
krewat's Avatar
krewat
Theoretically, the washers would allow a more-accurate torque reading on the bolts...
I see the buy it now is $29, for the extra $70, get an ARP stud kit, and get the best of everything... a very reliable brand, and studs instead of bolts.
Summit racing has the ARP head stud set for $99.95, check the sponsors here first though!
Old Jul 25, 2005 | 06:10 PM
hiball3985's Avatar
hiball3985
been working on FE since 1964, never saw washers on head bolts from the factory
Old Jul 26, 2005 | 03:15 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
BTW you guys were right on this. The FE never came from Ford with washers on the head bolts. Some rebuilders use a thin hardened washer sometimes. Most of the FE's I've had apart also used hardened washers under the head bolt so I... *** U ME ed it correct and oem. Thanks for keeping me straight on this. Hiball, pretty cool you have been working on these since 64. I was only a wee lad of 6 back then. I dug out the head bolts off the 406 and they had no washers either. Sorry about that guys. G.
