oil filter leaks any idea why??
my oil filter leaks between the housing and the filter i've tried 3 different filters stock fram, motorcraft and motorcraft powerstroke filter. i've tighten the crap out of it, and intsalled it like you should im out of ideas. although it doesn't leak that bad two quarts every 2500 miles and some of that comes out the rear main that i'll fix when the stock clutch goes
On my 6.9 original engine when I changed the filter I tightened it hand tight. Then with a filter wrench I tightened it 1 1/2 turns more. Any less and it leaked. But the bad thing was then trying to get the filter off the next oil change.
I used to take my own oil & filter to a Valvoline Quick change place in the winter for oil changes. After they broke three filter wrenches trying to remove the filter, they refused to change my oil after that. I have been using the same filter wrench for 10 years. So I just did it laying in the snow after that. The long Fleetguard (LF3630) filters do make it easier to get them back off, the wrench is below the frame so you can torque on it.
I need a garage my truck will fit in.
on
I have always used a large set of channel lock plyers for removal and found that while working at a Ford dealership I was able to remove almost every oil filter 100% of the time. I use a strap style filter wrench to do the tightening.
