Aerostar Ford Aerostar
Uh Oh - Tiny Bubbles
Old Jul 22, 2005 | 11:26 PM
aerocolorado's Avatar
aerocolorado
(With apologies to Don Ho)
Tiny Bubbles (tiny bubbles) in the Green
Makes me wacky, makes me scream.
Losing coolant, makes me dread
its the gasket in the head.
Tiny bubbles (tiny bubbles) feeling low,
Could be time now to let her go.
Should I keep her, yes I should
I must have a head of wood.
Old Jul 23, 2005 | 12:54 AM
copper_90680's Avatar
copper_90680
Hi Aero:
Check the lower radiator hose. If you have a pin hole there, you would see small bubbles. I seem to recall that a head gasket leak will result in bigger bubbles that go BURP once in a while. The way you maintain your car, it's hard to imagine head gaskets leaking on you, but then at over 200K miles, one should expect anything
Even if worse comes to worst, I sure hope you would decide to rebuild the old girl and stick around a little longer. What are we going to do without you here?
Old Jul 23, 2005 | 12:56 AM
koalamazed's Avatar
koalamazed
im in that situation now.....
95 4wd ext fully loaded, nice shape, and uh oh, wife overheats it one time and poof the head gasket blows. tiny bubbles in the radiator, D'oh! yet, no steaming exhaust, and not water to oil, oil to water transfer.
to sell or not to sell. that is the question! to fix and then sell? or to fix and then keep? GRRRRRR i dunno!
Old Jul 23, 2005 | 01:17 AM
Nappers's Avatar
Nappers
Talking Crud
You can't leave us Aero!!!! Hell, drop a 5.0 in her with a Paxton supercharger and let her rip.
L8R
Aaron
Old Jul 23, 2005 | 02:59 AM
96_4wdr's Avatar
96_4wdr
Talking
Yes, Yes
Let that Ole Aero go to the Happy Ford Junkyard in the Sky. She Has Earned A Rest.
Then visit the friendly Banker and with a wheel barrow of fresh loot, make a bonzi charge on the nearest Honda Odessey dealer.
As they grim and tell you domo arigato for the $35,000, they deliver your new Happy Van in Sushi brown with built in Fish Oil Aroma.
1 Year Later and You Too Can Dream of the Old Aero Days and the low cost parts and service. Now It's $10 Honda Oil and $12 Honda Premium transmission fluid which One Must Use or the Warranty is Hari Kari. And Don't Even Ask about Replacing the Transmission, If One Has to Ask the Price One Can't Raise the Yen for It.
Oh, Did I Tell You About the Short Seat Backs, Made for 5'5" statures and the 10 Year National Debt Loans. Both the Van and the Owner Are Worn Out When Paid For.
Old Jul 23, 2005 | 05:41 PM
aerocolorado
You guys are always good for a grin. Love the humor and the rest of the post was pretty close to the truth I imagine. Copper, welcome back from vacation. I replaced that lower hose either this winter or or last fall when I replaced the radiator - but I'll check it again. There are no leaks anywhere, just mysterious loss of all reservoir coolant over a 2-3 week period of time and subsequent near overheating episode. Nothing serious so far but with temps in the 100's out here the old gal is working hard these days. If the gasket is leaking it must be small as no odor or other telltale exhaust signs. After refilling the radiator yesterday I observed lots of small bubbles rising to the surface - almost effervescent in appearance. Not the lone, large, slow risers I observed when the Taurus blew a headgasket. Where else could air enter the system or coolant leak out undetected?
Old Jul 23, 2005 | 07:00 PM
96_4wdr's Avatar
96_4wdr
Reaching down into the neck of the radiator fill neck, any greasy black sooty deposits? Tell tale for blown head gasket or cracked head into exhaust port.
Some manuf. used to make a strong aromatic liquid that mechanic could put in cooling system and if there was a cooling system leak into exhaust, aroma would show up at tail pipe. Haven't seen it for years?
Why don't these auto manuf.'s learn and put in compressible stainless steel head gaskets. With all these dissimilar metal corrosion problems and short head gasket life they must make a fortune on the service, new vehicle market.
Old Jul 23, 2005 | 07:52 PM
lasher's Avatar
lasher
flush the system,install a can of pellet bars leak and new antifreeze and keep on going.
ive gotten by for two more years doing this and still going.
i know that the head caskets are prolly the cause
ford is known for this problem
Old Jul 24, 2005 | 12:15 AM
Nappers's Avatar
Nappers
yup
Aero, I use liquid Dawn dishsoap in my radiator, believe it or not and you would not believe the crap that comes out. I run it with dawn in it then drain and flush. makes a nice soapy pile when done. then maybe the bars leak. be careful though, I used it in my '64 Chevy p/u with 350 and clogged everything up, including the heater core. I use that powdered aluminum looking stuff. works great. just use it when you flush.
L8R
Aaron
Old Jul 24, 2005 | 12:07 PM
93nighthawk's Avatar
93nighthawk
Originally Posted by Nappers
....then maybe the bars leak. be careful though, I used it in my '64 Chevy p/u with 350 and clogged everything up, including the heater core.....
Did the Dawn or the Bars clog everything up?
Old Jul 24, 2005 | 03:54 PM
roree's Avatar
roree
K&N block seal lasted a long time in my old beemer. Just be careful of that $30 a can blue stuff.
Old Jul 26, 2005 | 12:33 PM
EBTDM's Avatar
EBTDM
Areo,
You have helped so many; you cannot count those who want to help you.
I use an industrial rust inhibitor that I got from a commercial HVAC guy. I do not know what it is called. A couple of ounces literally turns that nice green antifreeze a deep rusty (go figure) red color. It stains everything. I have found some very small pinhole leaks by looking for that stain. Just something you might want to try to run down in your area.
Old Jul 26, 2005 | 01:22 PM
copper_90680
Hi Aero:
Intake manifold? Water pump? Still a chore to contend with, but much less painful than head gaskets. At any rate, even if you have to redo the head gaskets, it should be easy enough for a man of your flexibility and dexterity
By the way, could it be that your water pump is cavitating, producing these small bubbles?
So, what are you going to do? New van or CPR on the old girl?
Old Jul 26, 2005 | 03:12 PM
aerocolorado
(best John Wayne imitation) Well now pilgrims, I just haven't decided yet what to do with the old girl.
Thanks to all for the various creative thoughts. I'm driving around with a jug of water and a gallon of coolant between the seats. The old fossil is sucking down about one gallon of coolant every 300-400 miles. Still no leaks either while running or sitting overnight. With this much coolant disappearing, she still runs just fine, no missing, no odors and no mileage loss. Other than an empty reservoir you would never suspect a thing was wrong.
The water pump, manifold, pinholes and other suggestions were pondered, but I think there is a small scale exchange of fluid for air going on in one of the cylinder heads - meaning a small gasket leak. What really need to do is pull #5 plug and re-check it for deposit confirmation. (This one looked odd at the last plug change.) Of course, that would spoil all the fun.
Old Jul 26, 2005 | 03:45 PM
bertha66's Avatar
bertha66
My Father-in-law went about 50,000miles using water glass in the engine, because of a leaking head gasket. Unfortunaly the old Aero passed just before he did.
