Chip vs. Tuner?
Old Jul 22, 2005 | 06:44 PM
erhvette790's Avatar
erhvette790
Chip vs. Tuner?
I have a '00 f250 PSD, and am hoping to get better mileage. I get about 16 MPG currently. Can anyone explain to me the difference between a Chip and a Microtuner? The superchips tuner seems like the thing to get, but the chips are a lot cheaper. What are the performance differences between the two, and will I get similar MPG increases from both?
Old Jul 22, 2005 | 08:56 PM
fishmanndotcom's Avatar
fishmanndotcom
i dunno where your looking at chips but they are normally more expensive. what chips have you priced and where?
the difference is a tuner is more universal, yes it works and works well but it doesn't take in consideration current mods (exhaust, chip, intake, propane injection)... also the tuner is plugged into a port beneath your dash and the truck has to be turned off and turned on to let the computer cycle through to make the changes.
a chip however is usually custom (hence the more expensive bill) and it is burned according to how your truck is setup. it is plugged in at all times unless you take the truck in for service or you are having another chip put in.
since you are looking for more MPG's you'd prolly get the better deal by going with a tuner.
-cutts-
Old Jul 22, 2005 | 09:13 PM
JRB's Avatar
JRB
Chip/Tuner
Also a lot of chips will allow you to switch to different levels of horsepower and with the tuner you will need to change the program each time. The chips usually cost more, but it's a lot easier to change the horsepower settings.
Old Jul 22, 2005 | 09:20 PM
bigdaddyTank's Avatar
bigdaddyTank
Before you go with either one, get gauges, those are a MUST if you plan on any upgrades to your truck. At the very least get a Pyrometer to keep an eye in EGT's.
Another reason in Chips costing more is that most of them offer 4 or 6 different settings, were a tuner gives 3 plus stock. Shifting on the fly is a very nice feature. To get everything out of a good chip you would want to upgrade exhaust, intake, and somthing to help the tranny like a Sonnax/tricum, upgraded valve body, or shift kit. The same could be said with a tuner like a Predator also. OH did I mention Gauges? You need those
Old Jul 22, 2005 | 11:34 PM
ceetwarrior's Avatar
ceetwarrior
Like bigdaddy said, a pyro guage is a first! I have a Diablo chip, very sweet and was around $340 shipped if I remember.
Old Jul 23, 2005 | 08:49 AM
edub32's Avatar
edub32
Like bigdaddyTank said, shifting on the fly is a really nice feature. From what I hear, the Predator takes about 4-5 minutes to load a program. So then, you probably miss a lot of races against some riceburners ... I'm getting a Predator though because it fits my application the best and I really like all the features.
Old Jul 23, 2005 | 08:52 AM
fishmanndotcom
ehhh just leave it on high performance
-cutts-
Old Jul 23, 2005 | 10:00 AM
mjwhip2's Avatar
mjwhip2
The only reason I went with a tuner is for the code reader. Made it a whole lot easier to justify the expense to the wife. Now I'm trying to talk her into a nice chip. You know, so I can change settings on the fly to keep egts down while towing.
Old Jul 23, 2005 | 10:57 AM
arninetyes's Avatar
arninetyes
...and still be able to read codes with the tuner. Yeah, that is what I'm planning! I have some other things I want to do (replace the intercooler, BB turbo, ), then I'm going to look into (maybe) having a custom flip chip burned by Jody Tipton.
Someday.....
Old Jul 24, 2005 | 09:15 AM
erhvette790
Thanks for the info guys...much appreciated
Old Jul 24, 2005 | 10:43 AM
johnny8's Avatar
johnny8
i got the predator tuner so i could use some different tunes and see what my mule likes... i am going to put a 6 position chip on but i am waiting till i get all my mods put on the truck... that way the chip can be settup for my truck.. my combination of mods.. and the things i am going to use my truck for... in the meantime... i can use my predator to "play"...!
