Offroad & 4x4
Another Rear Leaf Spring to Front ?
Old Jul 22, 2005 | 12:04 PM
ramboss429's Avatar
ramboss429
Currently on my '67 2x4 to 4x4 conversion I only have rear lift springs. I decided to get another set of rear springs to lift my front.
I have Skyjacker 4" springs in the rear with a shackle flip, and no block. There is roughly 5" of total lift in the truck over a stock highboy if my calculations are correct.
So, what rear springs would I need to buy for my front? I know they need to be 3" wide, and I plan on totally eliminating my drop front hangers.
Old Jul 22, 2005 | 12:10 PM
Thomsen's Avatar
Thomsen
with taking out the drop hangers I would use the same 4'' springs as the rear...unless they are not 3'' wide.
Old Jul 22, 2005 | 12:50 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
they arent 3 inches wide.... im running skyajcker rear 4inch lift springs with a long aal up front, and its great, gives me 6 inches with stock hangers
Old Jul 23, 2005 | 09:26 AM
brokebronco's Avatar
brokebronco
Kubota, what mods did you have to make to the front/rear mounts? Sounds like this may be a good solution for me.
Chris
Old Jul 23, 2005 | 01:06 PM
ramboss429's Avatar
ramboss429
I think I am going to run a Superlift 5.5" rear spring up front with home brewed "stock" hangers. I will more than likely have to add a 2" block in my rear to level it out.
Old Jul 23, 2005 | 04:15 PM
KubotaOrange76
Chris
just moved the front mounts foward 1/2 inch
Old Jul 24, 2005 | 09:10 AM
brokebronco
Really? I figured it would be more. I guess I need to go look at the truck again and bust out the tape measure.
Chris
Old Jul 24, 2005 | 12:14 PM
KubotaOrange76
i wouldnt use those superllift springs, they only have three leaves and a flat overload...my buddy has a set on his 79 in the rer...they are waaay tooo soft for the front of a truck
Old Jul 24, 2005 | 12:25 PM
Bacon2781's Avatar
Bacon2781
I have a 78 f-250 4x4 and am wanting to raise it 3-4 inches. What would be the best and cheapest way to do it? I was told to go to the scrap yard and find 2 sets of rear springs and just replace the front ones and add the others directly to the rear???? Will that work or is someone feeding me bs?
Old Jul 24, 2005 | 04:11 PM
fishmanndotcom's Avatar
fishmanndotcom
Bacon2781
first off, you hijacked someone elses thread. we are all talkin about using springs in the front and then you come and ask the age old, most annoying question ever *in urkel voice* "whats the best/least expensive way to lift my truck?"
secondly.... DO A FRIGGIN SEARCH! its been covered on MANY occasions!
-cutts-
Old Jul 24, 2005 | 11:31 PM
ramboss429's Avatar
ramboss429
Buy a lift kit from Skyjacker.
Old Jul 27, 2005 | 02:12 PM
Thomsen's Avatar
Thomsen
Grant...I just measure the rear leaves on our 89 F-350 and the springs are 3'' wide...
Old Jul 27, 2005 | 10:59 PM
ramboss429's Avatar
ramboss429
Thomsen - thats what I'm looking for, just need to find some that aren't too soft. I really don't wanna dish out the cash for skyjackers, but I might have to yet
Old Jul 28, 2005 | 02:18 AM
KubotaOrange76
if you can find rears from and f-350, they will work great, especially if they are the 6 leaf ones
Old Dec 27, 2005 | 11:12 PM
ramboss429's Avatar
ramboss429
I decided to order a set of rear springs for my truck and totally re-do my front suspension to totally eliminate that drop hanger I have now.
I am going to order up some Pro Comp rear springs (4").
What year of a truck should I say its for, I need to make sure they are 3" wide. So should I order for an '89 F350 like Thomsens truck?
