T-Link Part#??
Old Jul 22, 2005 | 08:29 AM
opnekryan's Avatar
opnekryan
T-Link Part#??
Does anyone have a nappa part number for the T-link that connects the boost to the map line?? I have the Autometer Gauges. 99' f350 PSD
Old Jul 22, 2005 | 09:02 PM
1997F-350's Avatar
1997F-350
i used some vacu tite fittings found at any parts store. if you look at the link in my signature you will see what it looks like under the vc's gallery. i also have autometer gauges . the white pieces are self explanatory and the black piece is called an 1/8 th in. soft elbow. one end of it will grip the hose refer to my pics. and dont shove it all the way in or it wont flow right and will give low boost numbers. i am the only person who i have ever seen it done like this but i was trying to go searching for all the brass pieces to make it work. but i am sure any hardware store should supply all that stuff also. good luck
Old Jul 22, 2005 | 11:27 PM
cangim's Avatar
cangim
Don't know part numbers, but I bought a bunch a TEEs at a hardware store, one item that I bough was a 1/4" tee with an 1/8" FP fitting is the center. Would of worked great with the exception the MAP line is more like 5/16 or 3/8" line. I ended up using a 3/8" tee with an 1/8"MP to a union then to the fittings that came with the kit. Wishing I'd gone back to see if they made a 3/8" Tee with 1/8"MP fitting, would of made for a cleaner install. Probable will still do it just because it is driving me nuts knowing that it would look better under the hood.
Old Jul 23, 2005 | 07:45 AM
opnekryan's Avatar
opnekryan
Welp, I managed to get er done with a 1/4x1/4x1/4 tlink... just used a simple rubber connector to plug in the 1/8 boost line to the top of the 1/4 T... Looks grrrrreat! Thanx
