2-speed rear end in a Ford car?
Originally Posted by 85e150six4mtod
Two speed diffs: Just rented an F800 diesel with a 5 speed Clark and a 2 speed rear. Not sure what year it was, as it was beat to crap. The only time the 2 speed shifted was when I was coming down the hill out of the Schoal Canyon land fill. I had tried to shift it earlier, but it wouldn't shift. Anyway, I got it into high range and left it there, as it wouldn't shift even after that. With the low first and the short trips I made, I got by without it. Not sure why a rental outfit would have a 5 & 2 set up. Last one I rented had a 4 speed automatic behind a diesel. It was newer, and had a/c and an AM/FM too. Haul in style, I say.
Don't down shift a 2spd rear going down hill, It can hang up and lock between gears then ur screwed.
DT
Not sure on the DJ's.
Got mine (torque splitter) from Advance Adapters. Here's a pic from their catalog.
http://www.advanceadapters.com/catalog/043.html
The trans/transfer case assembly does have to be moved back 7 1/4 inches.
That's how deep the splitter is.
Which means the drive shaft(s) have to made up.
I kept the original drive shaft just in case I removed the splitter.
It give me 8 speeds (2x4). The splitter goes from 1:1 to 27% O.D.
I'm not sure what you get in a 4x4.
Probably a wall climber.
They are pricey, that's for sure.
Got mine 19 years ago.
I learn't the art of the two speed from dear old dad in our '58 F 600. He would usually only use it as a "5th" gear on the 4 and 2 set up. The way that trans was set up, you could split each gear without a problem, even on down shifts.
But the normal upshift is, as you say, pull up the button, pause, lift the throttle, feel the shift and gas it.
For the down shift, wait for it to lug a little, push the button down, stab the clutch in and out as fast as you could with the throttle down.
I was in a much later model Chev 2 ton and it shifted no matter what the guy did, so maybe the later 2 speeds weren't as fussy.
I one I rented just plain wouldn't shift, except for that one time when it came out of gear by itself several miles, including stops and backing, after I had tried to shift it. Of course the Clark popped out of 2nd under load a couple of times--lucky to have a leg and hand after that.
lichtyr
06-12-2015 03:25 PM
jwmustangman
04-18-2011 12:33 AM
