Offroad & 4x4
help with auto hubs
Old Jul 21, 2005 | 09:56 PM
ajc766's Avatar
ajc766
help with auto hubs
I have a 2000 f350 psd 4x4 with auto hubs. when I switch to 4x4 it does not go in and after about 30 seconds or so the a/c switches from blowing out the dash to out the defrost and stays like that until i switch out of 4x4.the hole time never going into four wheel drive. can anyone tell me what is going on? thanks for your help in advance.
Old Jul 22, 2005 | 09:39 AM
goodie350's Avatar
goodie350
I know when the air changes from vents to defrost you have a vacuum leak somewhere. Don't know if your auto hubs are vacuumed controled or not but since it happens when you switch to 4x4 and corrects itself when you switch out it could be. It might give you a place to start. I have manual hubs so don't know much about the auto.
Old Jul 22, 2005 | 12:48 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
how is your vaccum pump??
Old Jul 22, 2005 | 09:50 PM
T_Moss's Avatar
T_Moss
Did you check the vaccum line going into your hubs?
It may look attached to the hub and ok but pull it off and check to see if it is clogged or dry rot.
