Sponsored by: Kumho
axle pivot bracket
Old Jul 21, 2005 | 06:50 PM
5.8L95f150's Avatar
5.8L95f150
axle pivot bracket
i have a 95 f150 and iam getting a 4" lift and iam looking at what it comes with and it comes with some think called an "axle pivot bracket" i have seen them before but iam not sure how they work or how to put them in.
also if any one could tell me a good place to buy some tires that would be great (33")
Old Jul 21, 2005 | 07:44 PM
Popa Tim's Avatar
Popa Tim
I'm not sure what you mean, did it look like this?
http://broncograveyard.com/bronco/i-...ng_shackle.htm
Old Jul 21, 2005 | 10:23 PM
5.8L95f150's Avatar
5.8L95f150
no there something like these
http://www.suspensionconnection.com/...con/20852.html
Old Jul 21, 2005 | 10:24 PM
5.8L95f150's Avatar
5.8L95f150
i just cant find out how to adjust them or why you need to adjust them
Old Jul 21, 2005 | 10:38 PM
Mark Wenner's Avatar
Mark Wenner
I've generally seen those referred to as axle drop-down brackets. When you install your 4-inch lift coils you have to drop the axle mounting points down to compensate, hence the drop-down brackets you mention. The adjustment feature is to make the front end easier to align. When you get the lift I'm sure this will all become very obvious.
Old Jul 21, 2005 | 10:49 PM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum.
70-360fe
Sep 30, 2013 02:09 PM
95centurion
34
Apr 1, 2011 01:13 PM
USMC35thSS
Mar 10, 2011 07:29 PM
