Just a little tip...
Originally Posted by fast freddie
The weather down here on the Gulf Coast has been really hot and humid as per normal for this time of year. The climate will let you know real qick if your AC is functioning properly. Well the system on my 95 just wasn't up to snuff even though all the usual checks showed no problem. I decided to take a look at my evaporator coil by removing the blower motor. An inspection with a flashlight and mirror indicated the problem. The coil was filthy. Had a complete covering of lint/dirt over the entire surface and even a piece of paper covering part of it. Cleaned her out with a water hose and some Mean Green. Workin' like a new one now. Not a real difficult task if you have a hankerin' to check yours. Had to remove the washer fluid reservoir in order to get the blower motor off but it only has two bolts so no biggy...
I was having a problem with my Max A/C setting. When i turnd on the max setting the air flow would cut in half of what the normal a/c setting was. I was reading on here last night for some tips or answers to my problem. I found a thread where a guy had a tacobell rapper stuck in the intake. So i poked my head under the glove box and wouldnt you know it. I found a plastic grocery bag stuck in there. I removed it and i was "blown" away. Just another reason i love this website!!!!
Another question...when I pulled the fan out, I could see thru to the bottom of my truck. I know this is the fresh air intake...but...the a/c was left in the max position when the key was turned off. Wouldn't the flapper have stayed in the max position, thus I couldn't have seen all the way thru. I almost always run the a/c on max, so all the junk collecting in the evap coil kinda puzzles me.
I was telling a mechanic friend of mine about your problem of not being able to see much of the evap coil and he showed me a can of coil cleaner called "Cool-it". It comes with a fairly long piece of small diameter tubing that you connect to the can and use it to spray around inside the blower box. He said the stuff dissolves the lint/dust coating so that it just drains out the bottom. Also said it leaves the ductwork smelling great! He also said that he sometimes has to drill a small hole in the box in order to spray the entire coil....
Originally Posted by joegebff
What is the process for accessing the entire coil, such as in replacing it, and how big of a pain would that be?
this wold be an avg of 5-9 hrs on most vehicles.
so unless it is leaking... definetly clean the fins on the evap core first.
