Ball Joints.
Old Dec 1, 2002 | 10:44 PM
Mistro's Avatar
Mistro
Ball Joints.
I am repalcing my worn ball joints and when I got my new ones ther is a replacement threaded top angled spacer. The part that screws into the top spindle arm on the dana 44 axle tube for the taper of the ball joint. Now, do I have to replace this, because it looks like you need a special tool I have never seen before or a hamme rand chissel. thanx
Old Dec 2, 2002 | 08:37 AM
tall1's Avatar
tall1
Ball Joints.
This threaded insert sets the preload on the balljoint. The solid design of the axel needs this for adjustment as all ball joints aren't made identical. I have known guys who dont replace it, but they seem to go through ball joints often. There is a special tool, a four prong socket, but i have removed them without it. If you can find the split in the old one and clean it out with a pick or hacksaw blade removal will be easier. There is a torque spec for these spacers, but I dont know it- I just snug them up good after the bottom joint is torqued and before the top joints nut is installed. BTW I gotta do mine this week also.
79 F150 4x4 stepside
As tight as you can and one more turn.
Old Dec 2, 2002 | 11:33 PM
Mistro's Avatar
Mistro
Ball Joints.
What is the name of the tool? Thanx
Old Dec 3, 2002 | 12:02 AM
Mil1ion's Avatar
Mil1ion
Ball Joints.
Curt's05
Jul 15, 2013 06:55 AM
griiz
Aug 11, 2009 03:46 PM
BMWM1
Jun 24, 2009 10:23 AM
jimwesselman
1997 - 2003 F150
Apr 16, 2008 02:56 PM
Imaddog
1997 - 2003 F150
Apr 18, 2004 04:18 PM
