Need Help After market stereo install
Old Jul 21, 2005 | 08:31 AM
vapor619's Avatar
vapor619
Im installing a Pioneer AVH-P500DVD indash DVD. my truck is a 2004 f150 screw with the audiophile system. The stock unit has three plugs that goes into it. Does anyone know where i can get the wiring harness adapter for this unit or if they even make one.
Old Jul 21, 2005 | 09:07 AM
fordboy_52's Avatar
fordboy_52
yes, walmart should have this, if not im sure you can order them at your local parts dealer... they are easy to install and are color coded as well as detailed instructions..
one thing you might be wondering is that you will not be able to jerry rig your dvd player to play while moving, this model has a gyroscope inside it and it senses movement, so lets say ur friend is jumping up and down on the back of your truck, the dvd player will quit playing. if you want one that will play when driving you will have to find an older model, then just wire the one wire that says motion to a 12v source with power whent he truck is running
Matt
