Backup light wiring
Old Aug 14, 2005 | 06:16 PM
MustangGT221's Avatar
MustangGT221
Backup light wiring
I swapped a ZF into my F-150, and reconnected the backup light to the electrical connector on the trans. I went from an M5OD to a ZF. Now, my backup lights stay on all the time, and don't really work. I unplugged the fuse to shut them off. Do you guys know why that would happen? I figured the wiring would be the same and it would be plug/play...is it not? The backup light worked on the trans previous to the swap.
Old Aug 14, 2005 | 06:41 PM
quicklook2's Avatar
quicklook2
the switch on new trans could be faulty causing it to stay on.
Old Aug 14, 2005 | 06:44 PM
MustangGT221
While I don't rule that out, I figure that might not be the case....no?
Old Aug 14, 2005 | 07:11 PM
quicklook2's Avatar
quicklook2
you did not change anything else so i would check that first. my vette had a bad switch that did not allow the lights to work. did not look bad, but that was the problem.
Old Aug 14, 2005 | 07:29 PM
MustangGT221
Do you know how the switch comes out?
It occured to me that my statement may be interpreted differently. The ZF came out of my F-250, and in the F-250 it was working ok. Then I took the ZF out of the F-250 and put it in the F-150 and now the lights don't work.
