In the tech section, there is discription for converting an 85 F150 to 4X4 using a 79 F150 4X4 front end. It sounds like a bolt in. ?, would the same hold true for a 79 F250 2 wheel drive? Thanks, Elliott
Ford radically changed the entire frame and body for 1980. Frame widths and lengths, mount points for the I-beams, a lot of things.
Sure, given enough money and enough time, anything can be done. But I woud stay away from this unless you have your own steel mill.
JMHO
