Noise during idle and low speeds
Old 07-20-2005, 05:28 PM
champ7718's Avatar
champ7718
champ7718 is offline
Lets see if anyone has heard of this one...
I've got a '04 Lariat F-150 Supercrew, she's a beauty. Recently I've noticed a new sound coming out of the engine compartment of the truck. The sound only occurs while the truck is in drive and either not moving (stoplights) or barely moving (no gas, just forward momentum of being in drive at low speeds). Noise goes away completely if the truck is put in Park/Neutral. It sounds like a vibration and can be felt in the gas pedal when it occurs. Initially I thought it was related to the air conditioner and the recent heat waves that have hit colorado. But I've also noticed the noise/vibration when the air conditioner is not on. I'm beginning to fear that is related to TSB 4-17-5 relating to the rear axle clutch pack failure. The noise is exhibited through the engine compartment however... Any ideas?
Old 07-21-2005, 01:35 PM
bamorris22's Avatar
bamorris22
bamorris22 is offline
I have the EXACT same noise. I've been searching for several weeks for info on it; but to no avail. I've been under & over the engine many times, but still no luck. I don't want to take it to the dealer because I already know the "we can't duplicate the problem" or "it's normal" lines...
I've also searched to 'other' f150 site, again to no avail...
Old 07-23-2005, 09:11 PM
bamorris22's Avatar
bamorris22
Bump for more responses.
Old 08-10-2005, 03:09 PM
champ7718's Avatar
champ7718
Took the truck in last week and had them take a look at the issue. I've installed a aftermarket K&N cold air intake (series 77) on the truck and it turns out the intake has been rubbing against my power steering reservoir. This was causing the vibration that I was hearing at low speeds. The tech simply installed a small piece of rubber adhesive to the power steering reservoir where the intake was rubbing on it and the sound has almost completely disappeared. Hope this was of some help...
Old 08-10-2005, 04:55 PM
Eric Landstrom's Avatar
Eric Landstrom
Eric Landstrom is offline
My '05 has the noise. From the cab it sounds like something is rattling lose. I brought the truck in and the dealer couldn't duplicate the noise.
Jeff396
53
05-22-2012 06:27 AM
jjoel
06-11-2010 06:24 PM
fpratt
1997-2006 Expedition & Navigator
12-09-2005 12:14 PM
HaroldCallahan
1983 - 2012 Ranger & B-Series
09-01-2005 07:22 PM
emtabmm
12-19-2003 09:04 AM
Quick Reply: Noise during idle and low speeds
