need help from forum with my truck!!
Originally Posted by RC Dan
When the engine is warming up, the truck is running in "closed loop" mode wich means its bypassing the ECM a.k.a. PCM a.k.a. ECU(main computer basically). When the truck has reached running tempurature(usually about 175 to 185), it switches its controls over to the ECM. If the ECM is not working, the truck will barely run or not run at all because all the signals used to run the ignition will be way out of wack or gone completly.
Another thing you may want to try is to disconect the SPOUT connector after it dies and see if the engine will run then.
ok - I swapped the ECT tonight and started the truck up, after 15 mins it was up to temp and it died while idling.
AndyM - I pulled a plug and you had it , no spark. I am baffled now.
So far I have replaced the following: ECT, IAC(that was bad) FPR, purge canister solinoid(that was bad). I pulled the codes and am getting 11's -
Any ideas out there? help a brother out!!
Memorex,
the heat failure with the TFI, does it let you start after it cools off? I could spray it with some freeze and see if the spark comes back - is there a test for the TFI other than swapping it?
Will it failing throw a code? I am getting and 11, I think that is a system pass ok -
Thanks to everyone who is helping me out -
Originally Posted by andym
What? The computer is bypassed when the engine is in closed loop? What do think is controlling the engine while it's warming up? Firing injectors, reading sensor data (like the TPS), controlling idle speed, etc.?
I don't know what that will do.
#28
Just for an update - I started it up and in 15 mins it died again - I popped the hood and gave the TFI module a good shot of can freeze (canned air held upside down) then tried and it started right up.
- This morning I got an autozone TFI (only place near that had one) and I installed it with a slight mod that might help with the heat. I placed a 3x5" piece of aluminum between the dist and the TFI. All contacted pieces had the conductive grease on them.
I started it up and it has not died while idling or when warming up - drove around for an hour and so far ok.
Does anyone have a prob with the heat sink idea? I figure it has to help somewhat -
Thanks to the guys who steered me towards the no spark check - that was a biggie!!
#30
Here is a follow up on the 15 min stall problem - It looks like the TFI was the reason for the no spark after warmed up problem. When I gave it a shot of freeze the truck would start ok - replaced the TFI and installed a homemade heat sink and drove it 75 miles in Illinois yesterday, air temp 100 degs. No problems so far - Thanks again to all who took the time to post a reply -
