Timing Specs.???????
Old Jul 20, 2005 | 11:16 AM
98blueoval's Avatar
98blueoval
I was wandering if anyone knew the timing specs for a 76 360 2bbl..All the books i have looked at so far,says "see under hood sticker"...Mine has no sticker under the hood..Thanks in advance.
Old Jul 20, 2005 | 12:39 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 20, 2005 | 01:09 PM
Mil1ion's Avatar
Mil1ion
Hello Blue oval & welcome to the site
You can find the info you're looking for in the FE engine series forum.
Old Jul 28, 2005 | 10:46 PM
rake's Avatar
rake
i power time my truck..forget the light..just drive it up a hill and tweak the timing untill it stops knocking
Old Jul 29, 2005 | 01:59 PM
fordeverpower's Avatar
fordeverpower
6 to 10 btdc. 6 is factory but 10 is better.
Old Jul 29, 2005 | 09:55 PM
Putt's Avatar
Putt
Set that with the vacuum advance disconnected and plugged.
Old Jul 30, 2005 | 02:55 AM
Bear 45/70's Avatar
Bear 45/70
I never have figured out why they tell you to disconnect the ported vacuum advance. If it is working right there is no vacuum on the ported vacuum at idle. Plugging it doesn't make much sense either as there is no vacuum to plug.
Old Jul 30, 2005 | 10:56 PM
Hypoid's Avatar
Hypoid
Because they knew somebody like me would try fumbling his way through it.
"If it is working right": Unfortunately not every one knows what "square one" is, or where to find it.
If it's not working right: At least a bonehead like me could get the initial right.
After a few decades of learning and reading, I'm still reading and learning.
Old Jul 30, 2005 | 11:00 PM
Bear 45/70's Avatar
Bear 45/70
If you ever quit learning, you might as well be dead or are dead.
Old Aug 1, 2005 | 03:32 PM
garyh's Avatar
garyh
I have a 1975 f250 390 4 barrell and the sticker on the valve cover states: 14 btdc, idle at 650 rpm. This is original as i bought the truck new.
Gary
Old Aug 1, 2005 | 03:58 PM
highrider76's Avatar
highrider76
timing
I got this from fe faq
"The factory timing initial advance specs on the FE are 6BTDC. Increasing the advance to 10 - 12BTDC can greatly increase your throttle responsiveness."
what will give the best fuel economy?
Old Aug 1, 2005 | 04:18 PM
rusty70f100's Avatar
rusty70f100
Usually more timing = more fuel economy, power, and efficiency, as long as you're not pinging. There are some engines that wont ping even when set for more timing than the setting that produces the most power, but this is a rare occurance for a pump gas burning, street driven engine. Also, it's not just a matter of more or less timing, you've also got an advance curve in there, so you could have too much at one rpm and not enough at another rpm. Then you throw vacuum advance in there... it gets complicated.
xevious
Feb 9, 2011 09:10 PM
lantzn
Dec 25, 2006 06:12 PM
White73390
Jan 30, 2004 11:46 AM
Hercdriver
Oct 29, 2003 03:16 PM
