I realize that there are many threads with regards to these codes but I thought I would start another with my 2 cents. and maybe help others save some $$$ if they ever have this problem
Problem...that danged 90 degree boot on the end of the hose opposite the pvc valve.
Solution...A) $25.78 from the dealer or B) a $5.00 plug wire from AutoZone (the boot on the distributor end of the wire fits great and is 90 degrees also.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
