plugged radiator?
Old Jul 25, 2005 | 08:42 PM
dbuck50's Avatar
dbuck50
What the??? I replaced the radiator (old one was a single core, new one is a 2 core). And it is still running hot compared to about 2 months ago. It has never done this and it isn't that hot here (upstate NY), currently 80, and tonight it was low 70's. I have replaced the rad, tstat, fan clutch, checked that all hoses were clear and clean, and flushed with a prestone kit for about 1/2 hour. The water pump was replaced about 20K ago, it couldn't be that could it? It isn't leaking at all. I can't figure this out. There is no buildup of junk on the AC condenser either to restrict airflow....this has me stumped!!!
Old Jul 26, 2005 | 08:42 AM
jtmerritt's Avatar
jtmerritt
Smile
Maybe the impeller on the water pump is slipping causing poor circulation of coolant. If you remove the cap when the engine is cold and start the engine you should be able to see water circulating especially after the tehrmostat opens. Might have to drain a little coolant to get room at the top of the radiator tank to be able to see the flow. Are you seeing any signs of a head gasket leak such as bubbles in the coolant at the overflow tank?
John
ERF
Jan 7, 2015 08:43 PM
1978f-250
Jan 10, 2014 03:11 PM
joel79ford
Dec 26, 2011 08:59 AM
Scratcher
Nov 20, 2010 05:10 AM
lharriger
May 23, 2010 03:47 AM
