timeing???
Old Jul 19, 2005 | 09:02 PM
payner22's Avatar
payner22
timeing???
i have a 93 efi 302 i was wondering if i can advance the timing so that i can get a little more horse power??
Old Jul 20, 2005 | 12:54 PM
Kemicalburns's Avatar
Kemicalburns
yes, your base timing should already be at 10*btdc with spout connector removed. you can go up to 12* safely. anymore will require some testing to see if the motor pings or not with a load on it. so if you want more then 12 only move up in .5 at a time.
remember to remove spout connecter when you do this otherwise it wont work properly. get a haynes manual to help with this process
Old Jul 20, 2005 | 09:35 PM
payner22's Avatar
payner22
ok thanks i do have a haynes manual too, will this give me a noticable amount of hp increase i just changed my plugs and wires distributor and rotor about 2000 km ago and that helped a bit
Old Jul 21, 2005 | 08:41 AM
Kemicalburns
it will be noticeable but not sure how much hp you would gain. maybe 1hp. what you get is better throttle response and quicker pickup and go feel
