Starter Problem - Fly wheel still functional?
Old Jul 21, 2005 | 07:27 PM
Hi Ho's Avatar
Hi Ho
I messed around with the switch for a while and I had it working well. I couldn't make it not work. I screwed the switch back in and started putting the steering wheel back on and I noticed that it was no longer working. Then I noticed that the battery was almost completely dead. I could not turn on the headlights without the radio going off. The radio has been on for several hours but that's it. The battery shouldn't be dead. I took the steering wheel off and the switch is intermintent again.
Old Jul 22, 2005 | 12:20 AM
Hi Ho's Avatar
Hi Ho
I charged the battery and messed around with the switch a bit more. I put everything back together and it seems to be working. I'll see how it goes. I guess I've been talking to myself here.
Old Jul 22, 2005 | 09:31 AM
rfxj3's Avatar
rfxj3
we're listening... but sounds like you got working for now. If you have to change out the switch, I think I remember seeing a couple of threads on that recently so do a search and you should get all the info you need. You'd be suprised at how fast a stereo will drain a battery. Especially if is really warm outside. Washington State probably doesn't have the same problem with this but down here in Texas, I have to replace batteries every other year it seems.
Old Jul 22, 2005 | 12:18 PM
Hi Ho's Avatar
Hi Ho
I've run the radio for hours on end before and not drained the battery. It was hot out yesterday, about 87, but I thought batteries didn't do well in cold weather.
Aviator2011
Bronco II
May 30, 2012 11:34 PM
Iam4x4
Apr 21, 2012 12:17 AM
vze2sgxa
Oct 28, 2010 07:15 PM
newwavedave
May 28, 2007 10:32 AM
danvestri
New Member Introductions
Feb 1, 2006 07:10 PM
