Sponsored by: Kumho
Tire pressure
Old Jul 19, 2005 | 07:43 PM
RyanMiller's Avatar
RyanMiller
Tire pressure
Hey, I noticed on the tires on my truck, the max rated PSI is 80 psi. I useualy run 45 psi, Are you supposed to run the max or close to it? I thnk that 75psi would help mileage wise.
Old Jul 19, 2005 | 07:53 PM
kingfish51's Avatar
kingfish51
You might be running a little low, but you don't need 75 or 80. That will just make for a bad ride and tire wear. With an F150, I ran 50 in my load range E tires and got good wear. As you have a 250 I would suggest a little higher, maybe 55-60.
Old Jul 20, 2005 | 02:26 AM
aurgathor's Avatar
aurgathor
The recommended tire pressure is in the user manual, and on a sticker on the door sill with a bunch of other info. Depending on your usage and tires, you may go higher or lower. Too high of a pressure will make the ride harsh and the tire will not wear properly. Unless you carry a very heavy load, you most likely don't need 75 psi.
pass1over
Mar 8, 2017 12:21 PM
tony montana 42
6.7L Power Stroke Diesel
Aug 10, 2016 01:34 PM
nomorecummins
6.4L Power Stroke Diesel
Sep 17, 2010 01:32 AM
whiteaddiction
Feb 5, 2009 03:38 PM
WKMOTZU
Mar 12, 2003 09:20 AM
