tachometer
Old Jul 19, 2005 | 12:45 PM
nevadabuddy's Avatar
nevadabuddy
tachometer
I have a two thousand F250 7.3 Deisel, 6 Speed, Tach works sometimes, any info appreciataed.
Buddy
Old Jul 19, 2005 | 01:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
Old Jul 19, 2005 | 01:06 PM
jesus_man's Avatar
jesus_man
I know the CPS (Cam position sensor) affects the Tach, but if your truck is running fine, then that doesn't seem to be the problem. CPS's are known for working or failing intermitantly. Other than that, could be a loose wire. Someone with more experience can shed more light.
J.D.
Old Jul 19, 2005 | 03:58 PM
nevadabuddy
tach
JD
Thanks for the reply. Have a good dY...
BUDDY
Old Jul 19, 2005 | 04:14 PM
bridgeman's Avatar
bridgeman
My 96's tach would do the same thing once in a while, gave it a good rap with my knuckle and it must have secured a connection because it has worked ever since. Quickest fix I've done in a long time!
Old Jul 19, 2005 | 08:33 PM
nevadabuddy
tach
tks for the help, i,ll keep trying, sooner or later!!
Buddy
