Engine Trouble Up-Date
Old Jul 29, 2005 | 11:34 AM
Randyb12's Avatar
Randyb12
He is talking about phasing. The way to chheck this is to take a old cap drill a large hole next a terminal. imagine a line from the center of the cap through a terminal put the hole on this line up against the terminal. Now put a timing light on the plug wire that is connected to the terminal that has the hole by it. Start the engine and see if the rotor is centered on the terminal when it fires. If it is off center adjust the baccking plate until it is centered. It might take a few tries to get it just right
Old Jul 30, 2005 | 08:47 AM
CVokie's Avatar
CVokie
I don't know if its one tooth off or not, the dist hasn't been out since 1992, the timing marks line up but someone else mentioned that, could that be the root problem? it runs OK now after i adjusted the pot. full advance is past the end of the 30 degree mark some. if it is timed at 6 btdc how far ahead would one tooth make it?
Old Jul 30, 2005 | 09:46 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
One tooth off would be 24 degrees as dizzy has 15 teeth, 45 degrees between terminal posts.
.....=o&o>.....
Old Jul 30, 2005 | 10:38 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Very good Carl on your math!!! LOL..JK!! But your right!!
Russ
Old Jul 30, 2005 | 11:01 AM
"Beemer Nut"
Russ, did you get your GTech?
BTW, can you post some photos, specs with numbers on your G heads when they return from the head shop? Yesterday I found one C4AE 6090 G head when I was looking for a log manifold for a friend at a truck wrecker. Manifold $50, core deposit on head $25 as they were both attached and they didn't want to seperate. Heck they can keep my $25. I've got four 454 heads (peanut port) from good running motors (boat that ran coolant) told they are worth $10 each, chebbies that cheap?
.....=o&o>.....
Old Jul 30, 2005 | 08:26 PM
CVokie's Avatar
CVokie
OK thanks, is there a way to see if i'm a tooth off without the bringing up the #1 to TDC? As for the phasing test, my dist does not have an adjustment option for the backing plate. I will check the dizzy alignment out because every since i overhauled the eng it has ran somewhat hot, no overheating just heats up at idle, slow traffic, and heavy pulls, it never overheated cause I'm not where i would bet stuck in traffic. I will check the distributer alignment, let me know if there is an alternative way to verify if its a tooth off.
Old Jul 30, 2005 | 10:49 PM
Bear 45/70's Avatar
Bear 45/70
Fan not big enough, clutch bad, no shroud or a weak water pump will cause idle overheats.
Old Jul 31, 2005 | 12:13 AM
"Beemer Nut"
Or radiator that's half plugged or a two row. That fan shroud is one major item in keeping the motor cool no matter whay type of fan you use. Fan clutches can screw up.
.....=o&o>.....
Boots & Slicks 14
18
Oct 9, 2015 07:31 PM
1capitalkid
All Things Towing
31
Jun 7, 2015 08:56 PM
tbolt64
Jun 2, 2013 10:25 AM
spinge
30
Nov 10, 2011 09:40 AM
airharley
Apr 15, 2011 07:05 PM
