new engine design
Old Jul 18, 2005 | 09:58 PM
F2504x4's Avatar
F2504x4
new engine design
http://www.dynacam.com/Product/Desig..._overview.html
Neat looking but will it be practical.
Old Jul 18, 2005 | 11:13 PM
fellro86's Avatar
fellro86
interesting... no wasted strokes, a fourcycle type that can run like a two cycle... no more wasted strokes. I don't see why it couldn't be put to practical use, if it produces the power they claim. I can see that it should, since it can push the piston back on the exhaust stroke with a power stroke...
Old Jul 19, 2005 | 08:10 PM
muscletruck7379's Avatar
muscletruck7379
interesting, but looks expensive
Old Jul 19, 2005 | 09:04 PM
rusty70f100's Avatar
rusty70f100
Looks like oil control will be a problem. You've always got a cylinder on the bottom, no matter how you rotate it. If it burns oil it'll never pass emissions. Interesting idea, but I dont see it happening.
OBTW, it looks like they adapted a swash (or wobble) plate compressor to make an internal combustion engine out of it.
Old Jul 19, 2005 | 09:24 PM
brown79's Avatar
brown79
looks like a hydraulic motor/pump to me
Old Jul 21, 2005 | 09:14 PM
roger dowty's Avatar
roger dowty
For those that know aviation you understand how that validates the system to a degree- it has to perform to make it in that field- even under experimental. I'd say it sounds like a helluva product. Time will tell. wish I had money to lose in an investment- could be a rich man someday or wiser.
Old Aug 8, 2005 | 12:48 AM
Greywolf's Avatar
Greywolf
That thing looks almost identical to an A/C compressor, the exception being that it has opposed pistons instead of a single set operated by the cam or eccentric plate in the middle.
The valve train would be a nightmare, I can see that. I note that the Wankel engine had fewer moving parts, but it had its own developmental troubles - mainly seals that went out around 70,000 miles.
The one advantage I see is that it has no radical shapes to cut out or machine. Wankel side casings had to be difficult to machine.
That cam in the center though, I wonder how tricky the bearing setup is?
It's different, I give it that. Something it has in common with the Wankel though is that it appears to be a design adapted from a type of pump. If you think about it, most compressors are set up very similar to a piston engine.
What would be real impressive is a turbine engine based on twin-gear oil pumps!
~Wolf
AK FORD GUY
Apr 13, 2013 12:00 PM
jayro88
Oct 18, 2012 11:22 AM
The Ledge93
Oct 16, 2011 07:04 PM
Slowroll90
Oct 6, 2011 11:14 PM
azazel696
Apr 7, 2011 12:16 PM
