tach install/info "94
Old Jul 19, 2005 | 09:12 PM
toby5181's Avatar
toby5181
My father inlaw has a 1994 f250 4x4 ex cab auto and wants to install a tach.
Any how to would be helpfull and a good place on the internet to get them from would be great. I never installed one on a diesel. THANKS A LOT EVERYONE
FTE WHAT A GREAT PLACE!
Old Jul 20, 2005 | 12:23 AM
PLC7.3's Avatar
PLC7.3
It should have a tach already in the dash cluster if it is an E40D trans........tell us more about the truck. Check the door post tag and tell us what trans letter E or G.
Old Jul 20, 2005 | 07:13 AM
toby5181's Avatar
toby5181
It Is A E40d Auto No Tach In The Dash I Read On Hear About A 1" Plug By The Oil Fill For A Sending Unit Is This Correct. I Have Not Looked At The Truck But More Info Is Coming!
Old Jul 20, 2005 | 11:06 AM
BikePilot's Avatar
BikePilot
Yep that's correct on the rpm sensor location. You should already have one as even without a tach the ecu that controlls the trans still needs to know how fast the motor is turning. I don't know for sure, but typically the wireing is already in place for the tach, all you would have to do would be to find an instrument cluster from a truck like yours but with a tack and plug and play
BTW my 1994 F-250 IDI TD has an e4od and factory tach.
good luck
Mtnhermit
Apr 30, 2016 12:57 AM
brobrad
1997 - 2003 F150
Jan 15, 2013 04:10 PM
F-250 restorer
Jan 30, 2011 03:42 PM
turdbird
Electrical Systems/Wiring
Dec 3, 2005 03:52 PM
IDfordguy
Sep 26, 2005 01:00 PM
