6.0 PSD Stalling possibly found
Old Aug 8, 2005 | 09:45 AM
  #31
kw5413's Avatar
kw5413
Completely follow Jeff's advise here and you cannot do the wrong thing.
Folks using the right oils with quality fuel additives here, at FTE, just seem to have fewer issues than those that don't.
In addition, IMO, don't listen to the people that recommend or advertise 25,000 mile oil changes. I don't care if they claim their product was derived from the nectar of the gods. Once you exceed the Ford recommended oil change intervals you just popped your entire engine warranty.
Some people are quick to point out how much their new 6.0 Power Stroke Diesel Truck cost and how Ford should do this or that...Then they try to squeeze every penny they can out of an oil change.
Old Aug 8, 2005 | 11:01 AM
  #32
dsweger's Avatar
dsweger
I'll add my oil observations here too.
I change at 5000 mile intervals, and have used Rotella (dino) for all changes.
For two intervals ( 10,000 miles ) over the winter months, I used Rotella 10-30 which so happened to be CI-4 rated (not PLUS rated). Occasionally the motor would stumble and produce light/white smoke on light throttle settings. If I pushed the pedal down harder, it would clear up and take off like a rabbit. I had the dealer look at it while it was in for the tranny reacll and they could not repeat the problem, nor could they find anything wrong in routine testing.
When it was time for new oil, I went back to the Rotella 15-40 which also happens to be CI-4+ rated. I have never experienced a "stumble" while running with the 15-40 Rotella ( another 10,000 miles ). My conclusion, based strictly on my own experiance is that my 6.0 likes the 15-40 weight oil better. I sent a sample to Blackstone 5000 miles ago, and have a new sample in the jugs waiting to go, and still have not seen any results, so I can't tell you what is happening to the oil from that perspective. I also find it curious that the CI-4 and CI-4+ ratings of the two oil weights involved, were also part of this mystery.
There does seem to be some merit in the use of the CI-4+ rated oils, at least in my mind, (however small it may be).
Old Aug 8, 2005 | 11:21 AM
  #33
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
CI4 and CI4+ are not oil weights.. but rather oil certifications and formulations. The CI4+ is a newer industry standard that reduces oil shearing and has improved soot control (over CH4 and CI4 rated oils).
According to Ford's latest TSB, 15W-40 weight oil should be used for the bulk of where and how we use our trucks. They allow 10W-30 (make sure it is diesel rated) for extreme cold weather operation, but not for towing!!
Jeff
Old Aug 8, 2005 | 01:38 PM
  #34
dsweger's Avatar
dsweger
Sorry if my statements regarding the CI-4 ratings seemed misleading. It just happened in my case that the two weights of oil that I purchased, had different ratingsath the time when I bought them. When I bought the 10-30 weight in anticipation of cold weather, I only verified that it was at least CI-4 rated and then in the spring when I purchased the 15-40 weight oil, it had the CI-4+ rating.... I did not mean to infer that the ratings had any bearing or influence on the viscosity.
My own experience with the two oil weights would help to validate Fords reccommendation to use 15-40 weight oil.
tjustice
24
Dec 23, 2014 11:06 AM
Sixgunjack
Mar 16, 2014 11:17 AM
gotime
Jun 22, 2013 05:15 PM
dieselator
May 20, 2010 08:49 PM
phydiux
Nov 4, 2008 09:49 AM
