1993 F150 4.9 Six Code Help
Old Jul 18, 2005 | 01:26 PM
fireman751's Avatar
fireman751
Help. I have a 1993 F150 4.9 that has a few issues. I had to replace the long block and my gas mileage went from 18 to 12 I had replaced the EGR valve, O2 sensor, egr position sensor and the thermostat(192 factory). My mileage still stinks and I have no power. I am now getting codes 33 and 53. Any ideas would be helpful. Thanks.
Old Jul 18, 2005 | 02:18 PM
MemOrex's Avatar
MemOrex
33-EGR valve opening not detected. Could be the EVP sensor (on top of EGR) that could be bad or broken EGR valve diapghragm. If you have a vacuum pump, you can test the EGR valve by applying vacuum on the small port.
53-TPS above 4.5Volts. How is your idle? This is probably your mileage and power problem. Replace the TPS.
EDIT.
Also, have you ever removed and reinstalled the TPS? When installed, the TPS voltage must be set.
Old Jul 18, 2005 | 02:40 PM
fireman751's Avatar
fireman751
The EVR sensor and the EGR valve are both new. The EGR was changed last week. I just bought a new TPS sensor and have not installed it yet. How do you set the voltage? Thanks.
Old Jul 18, 2005 | 04:31 PM
EPNCSU2006's Avatar
EPNCSU2006
Did you set the timing properly when you installed the engine? This could cause reduced mileage as well, but certainly correct the trouble codes you have now too.
Old Jul 18, 2005 | 04:36 PM
fireman751's Avatar
fireman751
The person that installed it said he set it to spec. But I believe it was a rebuilt longblock that may have been bored. What should I set the timing to? Again, Thanks for your help.
Old Jul 18, 2005 | 05:59 PM
EPNCSU2006's Avatar
EPNCSU2006
The timing should be 10° BTDC with the SPOUT connector removed. The SPOUT connector is located on the drivers side fender near the TFI module which is the thing in the heat sink. The SPOUT might be buried in tape, but it should be close by. My dad's truck was at 6 degrees when we checked it the other day, and now that it's at 10, he says it has much more power than it used to.
