Diff
Old Jul 16, 2005 | 08:00 PM
Bankz27's Avatar
Bankz27
Diff
I have a 92 f150 xlt 2x4 5.0L regular cap and I was wondering what type of back end do I have, what gear ratio, just want to know has much has possible to the drivetrain has I can
Old Jul 16, 2005 | 08:11 PM
quicklook2's Avatar
quicklook2
look at your decal on the door and post info.
Old Jul 16, 2005 | 08:37 PM
Bankz27's Avatar
Bankz27
My numbers are completely gone. The stick has been like peeled off
Old Jul 16, 2005 | 08:46 PM
quicklook2's Avatar
quicklook2
on rearend you should have a tag, if you do not i do not know what else to tell you.
Old Jul 16, 2005 | 09:26 PM
Bankz27's Avatar
Bankz27
does anyone have a 92 f150 2x4 xlt and can you tell me what size is your axle and gear ration
Old Jul 16, 2005 | 09:50 PM
quicklook2's Avatar
quicklook2
they are all different, that is the problem.
Old Jul 16, 2005 | 10:56 PM
MRL123's Avatar
MRL123
I am pretty sure that this will work. You can roughly calculate your diff. ratio by jacking up the rear end and supporting the axle on stands. Place the beast in nuetral and then go to the back end. Slowly turn the rear tire and count how many times the driveshaft turns for a complete rotation of the rear tire. You have to make sure that your stop and start points for the tire rotation are the same. If the driveshat turns 3.5 turns for a complete tire rotation then you would likely have a 3.55 rear end. If I'm wrong on this some one else jump in quick.
Also, are you sure that there is no tag on the rear end? I know on my truck it is completely flat against the housing and buried under road spooge. It can be really hard to see and find. Take a second loook at each of the bolts that are on the rear end.
Oh yeah, dosen't the VIN number also contain information about the rear end ratio? At least with the VIN you could maybe run it through FORD and they would be able to tell you what the truck originally came equipped with.
Cheers!
Mike
Old Jul 17, 2005 | 02:01 AM
mecambello's Avatar
mecambello
And do several rotations of the tire for better accuracy.
Old Jul 17, 2005 | 11:35 PM
95X15's Avatar
95X15
If you have a tag on a bolt on the rear axle look at the first 3 digits on the bottom row of numbers - that should be the ratio for a Ford axle. Hope this works.
Old Jul 18, 2005 | 12:21 AM
phoneman91's Avatar
phoneman91
Bankz27:
Since you have a XLT--and if you have a tachometer--tell us the size of tire that you have and the type of transmission--and then tell us what RPM the engine is turning at 60 MPH in top gear--and we then will be able to tell you what axle ratio you have.
All F150s of that vintage had 8.8 inch,31 spline, Ford Corporate rear axles.
Old Jul 18, 2005 | 03:38 PM
jamiesan's Avatar
jamiesan
i have a 92
I have a 92 4x2 300 six w/ 5spd. the rear end is of course an 8.8. the ratio is 2.73:1. ( code 12) on door jam. YES your vin tells you. give me your vin# and I'll get back to you. PS if you have your owners manual you can do this yourself!
Old Jul 18, 2005 | 06:11 PM
andym's Avatar
andym
Wow, there's a lot of wrong information in this thread.
- the VIN does not contain any information about the rear axle ratio.
- the above method for calculating the gear ratio is slightly incorrect.
- you have an 8.8" rear axle. No doubt about it.
The one thing that's right is that the axle ratio will be on that tag. But sometimes someone will change the fluid and leave the tag off. If that's the case, do this:
Leave it in neutral, and jack ONE tire off the ground. Spin it around once, count the number of driveshaft revolutions, and divide by two.
Common ratios are: 2.73, 3.08, 3.55, and (rare) 4.10.
