NEWBIE NEEDS ADVICE ASAP!!!
Old Jun 4, 2001 | 09:09 PM
Pastmaster's Avatar
Pastmaster
Old Aug 1, 2001 | 12:01 PM
carmody's Avatar
carmody
Hi, Ford Lovers! My name is Carmody, and I live in Wichita, Kansas. I test drove a '65 F-100 last night, and I'm thinking of buying it. Is there anything specific I should look out for in this model?
It has a 352-V8 (owner claims it's original, but who's to say?) with exhaust manifold leaks (nothing too worrisome), the brakes are tired and pull a bit, and the clutch will probably need replaced soon. It is impossible to shift down into first if the truck is in motion at all, but goes into gear fine at a stop light. (This is not unlike my '63 Rambler American with 3-on-the-tree.) The truck was hit in the front fender/headlight by a small car recently, but none of the metal work interferes with the tires or steering.
The guy wants $500 for the truck, and I'm thinking of dickering up from about $350. You guys are the experts here...any advice you can give me in this situation? I really appreciate it, and thanks in advance. I can be e-mailed at nerv0usreNo Email Addresses In Posts!) or carmody@kcisp.net.
Thanks again!
Carmody
Air Capital, USA
Old Aug 1, 2001 | 01:10 PM
whomrig's Avatar
whomrig
Hi Carmody, welcome to the boards....If you have a granny 4-speed trans, that will never go into 1st gear while moving. If you do have a 3-on-the-tree, then you most likely have a syncro problem in the trans. As for the price, I am not an expert, but out here in California, 500 bucks ain't too bad for that.
Wayne 60 F-350
e-mail
http://home.pacbell.net/whomrig
Old Aug 1, 2001 | 01:39 PM
carmody's Avatar
carmody
Hey, Whomrig:
Thanks for the reply. It is a four on the floor with stump-pullin' low gear. I figured that was the deal, pretty much. I think I'm going to shoot him an offer this afternoon...I'll post either way!
Thanks again,
Carmody
Old Aug 1, 2001 | 02:14 PM
rocky's Avatar
rocky
I had one of those! Great truck, you'll have fun with it.
Old Aug 1, 2001 | 02:19 PM
TallPaul's Avatar
TallPaul
I would think that, if it runs and will get you from point A to point B, it definitely is worth 500 bucks.
Old Aug 1, 2001 | 03:11 PM
whiteboyslo's Avatar
whiteboyslo
352 V8. ah yes, the good ole FE block if I remember right. My first truck had a 360 in it (also in the FE family) and had an exhaust manifold leak as well. apparently, this was just something these blocks were known for. when i called around to shops to have it fixed, some flat out refused the second i told them which engine it was. go figure. anyway, as far as the price goes, guys that sell trucks for $500 are the reason i can't get rid of mine for a grand. if it runs and doesn't have rust holes you can see through, i'd buy it in a heartbeat. you can't break those FE blocks.
Old Aug 1, 2001 | 03:35 PM
carmody's Avatar
carmody
Whiteboy:
Thanks for your two cents. I get out of work here in an hour or so, and I'm gonna call him up as soon as I get home and see what we can work out.
Stay tuned!
Carmody
tonymancil
New Member Introductions
Nov 8, 2017 03:54 PM
USRanger379
Mar 24, 2017 02:25 PM
Sonicmjf
Dec 25, 2015 01:24 AM
robsimmons
May 10, 2013 03:38 PM
