soft brake pedal
Old Jul 16, 2005 | 05:20 PM
gfalin1959's Avatar
gfalin1959
Question soft brake pedal
ok,here i am with another question.i have a very soft and low brake pedal,i have replaced the following parts.front and rear pads and shoes,drums,rotors,spring kit and master cylinder.i bench bled the master cylinder and then bled out the lines five or six times,first with a one man bleeder and then with the tried and true pump em,hold em,bleed em method.is it possible i still have air in the lines somewhere,and should i just keep bleeding?it is a 1991 f150 4x4
Old Jul 16, 2005 | 06:02 PM
1990F2504604x4's Avatar
1990F2504604x4
On my 89 it turned out to be a cracked firewall, both the clutch and brake were soft and squishy from the firewall flexing.
Old Jul 17, 2005 | 12:30 AM
F250OBX's Avatar
F250OBX
Now there's one you don't hear every day! I have a similar prob, didn't even think of the firewall!
Thanx!
Old Jul 17, 2005 | 10:40 AM
gfalin1959's Avatar
gfalin1959
thanks for your help,i cheecked the firewall this morning and can' find any cracks so i am back to the theory of air in the lines or maybe the front hoses.i'm going to parts store now and replace those and bleed the brakes again.any thoughts,suggestions?thanks
Old Jul 17, 2005 | 05:31 PM
1990F2504604x4
Have someone push the brake while you look for flexing, plus when my master went out on my '90 going down a hill no less we replaced it and it was still soft and my abs light was on so we unhooked the batt. rehooked it then cycled the abs(going down street then slamming on brakes), i think that is the only way to also bleed the abs.
Old Jul 17, 2005 | 06:55 PM
gfalin1959's Avatar
gfalin1959
thanks,i'll try that my abs light was on but i took back the master cylinder i put on and now the abs light is out and i have more pedal.i still think there is air in the lines so i am going to replace all the fluid.
exegeses
Sep 2, 2021 03:47 PM
DreadyDiggs
Dec 6, 2014 05:11 PM
Dr-MorningWood
Jul 22, 2014 02:38 PM
85AustinTucker
Mar 7, 2014 11:06 AM
CollinsCD
26
Dec 27, 2013 02:10 PM
