No check engine light
Old Jul 16, 2005 | 04:56 PM
RTREV64's Avatar
RTREV64
Post No check engine light
Ok My check engine light is not on but I am encountering some problems with my Ford Ranger, 1999, with 96 thousand miles, a 3.0 engine, standared.
It rides smoothly and does not shake while driving, this has happend 3 times already, I start my truck up and it shakes for a second and idles very slow and it dies, does not dwd -Die While Driving.
The check engine light does not come on.. so hat do ya think?
Old Jul 16, 2005 | 05:43 PM
87 XLT's Avatar
87 XLT
Take a look at the "read first tech info" at the top of the Explorer forum & then click on "IAC repair/testing directions."
Old Jul 16, 2005 | 06:13 PM
el conquistador's Avatar
el conquistador
pull the codes
Old Jul 16, 2005 | 11:38 PM
RTREV64's Avatar
RTREV64
getting worse
when I turn it on, it idles very low like almost not on. everything is barley on. it almost dies when I am at a stop sign shakes some. it runs smooth but when I change the gear ie clutch is bangs alittle.
Old Jul 16, 2005 | 11:40 PM
87 XLT's Avatar
87 XLT
Could be a bad IAC. Did you look at the IAC repair link?
Old Jul 16, 2005 | 11:43 PM
RTREV64's Avatar
RTREV64
I was looking for the IAC link, could not find it.. please send me link.
Old Jul 16, 2005 | 11:50 PM
RTREV64's Avatar
RTREV64
I don't see IAC repair link anywhere..
Old Jul 17, 2005 | 07:29 AM
RTREV64's Avatar
RTREV64
Question the link
Can someone point to me the IAC link, I don't see it anywhere.
www.roberttrevino.com
Old Jul 17, 2005 | 07:34 AM
Bob Ayers's Avatar
Bob Ayers
Here is the URL for the IAC information:
https://www.ford-trucks.com/forums/s...hreadid=166103
I agree, I think your problem is the IAC valve. It is located on the throttle body. Most problems with the IAC will not set a code.....
Old Jul 17, 2005 | 07:47 AM
RTREV64's Avatar
RTREV64
Thank you for the link, I will just replace that thing and hope that is all it needs.. by the way, have a price on what that would cost? looks simple enough that I can repair it myself.. up front..
Old Jul 17, 2005 | 09:09 AM
Rockledge's Avatar
Rockledge
Another very good IAC thread:
https://www.ford-trucks.com/forums/s...hreadid=136188
Old Jul 17, 2005 | 10:58 PM
RTREV64's Avatar
RTREV64
Post My Iac
So this is where my IAC for my 99 ford ranger is located at?
Just want to make sure. sorry If I am not great on my paintshop drawing.
here is a quick clip vid of my engine. If you listen to it it goes up and down, it was worse before I was able to get the cam out to record it when it was doing bad.
http://www.roberttrevino.com/engine.wmv
Old Jul 18, 2005 | 05:34 AM
Bob Ayers's Avatar
Bob Ayers
Yes, that is the IAC valve......
