351M camshaft
Old Jul 16, 2005 | 02:14 PM
Fordman360V8's Avatar
Fordman360V8
351M camshaft
im planning on putting a stage2 RV cam in my truck as well as lifters and timing chain ive heard that ford retarded the cam timing in these motors from the factory im going to buy the timing chain so it can be adjusted i was just wondering how hard this is to do or if what i heard isnt even true so any input would be appreciated
Old Jul 16, 2005 | 03:09 PM
RR4E's Avatar
RR4E
These engines have low compression...the biggest down-fall.
A decent RV cam will trick it into thinking it has more compression by holding the valve overlap time a bit longer(both intake and exhaust closed at the same time, and a normal condition for any engine, but most don't hold it long enough)
I'd recommend a dual pattern RV cam from Competition Cams in the 260/270 bracket, and convert to a 4v intake(dual plane, Edelbrock torker series) and an Edelbrock 600 cfm carb for a nice improvement.
You'll have the intake off to replace the cam, and should also add new lifters and pushrods at the same time to make things nice and tight. Can't re-use old lifters on a new cam unless you want some problems anyways...the push rods are cheap, and have to be removed and replaced anyways.
While you're there, but a gasket kit, as they're cheaper than individual gaskets, and replace as many as you have the energy for. I'd go as far as installing a new high volume oil pump, and drive-shaft(driven off the distributer to oil pump) just to make sure all those things are in good order. Even a new distributor gear won't hurt, and the timing chain, since it will be off, should be replaced with a decent pre-stressed chain and roller bearing assembly, as the stock set-up is a slide chain, with nylon gears(not one of Ford's better ideas)
If you feel the need, and have the time, cleaning up your heads, and lapping the valves and replacing the valve seals(if you get the gasket kit, comes with valve seals and head gaskets) is never a bad idea.
it's a bit more work, but you're over half way there anyways, a little further will see a much larger improvement over-all. Up to you how much you want to do, but you'll notice a lot less oil leaks, valve seals are a huge contributor to oil burning, and a clean set of heads with freshly lapped valves will improve power and response.
crsweet78
23
Mar 26, 2024 04:31 PM
outdoorfan
13
Nov 14, 2013 08:13 PM
fishnowworknever
2004 - 2008 F150
Oct 28, 2013 05:13 PM
craigl58
Sep 13, 2006 09:16 PM
chrono4
Jan 26, 2005 09:51 PM
