differential ratio
Old Jul 16, 2005 | 01:02 PM
JimBanshee350's Avatar
JimBanshee350
differential ratio
Can someone can help me please, I have a ford f-100 custom 1979 2x4 and I need to know the differential ratio.
Old Jul 16, 2005 | 01:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 16, 2005 | 01:14 PM
Lane Dexter's Avatar
Lane Dexter
Where's that site for interpreting the codes on the door plate? Isn't the differential ratio on there?
Old Jul 16, 2005 | 01:28 PM
Mil1ion's Avatar
Mil1ion
Just click my web site link in my sig.
The axle ratios are determined engine & truck use not by year and model
Look for the code on the door & post it.
I guess 13,16, or 19
Old Jul 16, 2005 | 05:05 PM
Ecuri's Avatar
Ecuri
The tag may still attatched to one of the housing bolts.
Another way to determine/verify the ratio:
Get both rear wheels off the ground with truck in neutral. Using a chalk mark or some other such reference, turn both wheels one full revolution the same way at the same time (you will need a friend or extraordinarily long arms ). The number of turns of the driveshaft will be the ratio. There may be other methods, but this is what I was taught. GL
Old Jul 16, 2005 | 06:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is a good ratio determination method outlined in the Read First: FAQ thread above.
Old Jul 22, 2005 | 11:18 AM
JimBanshee350
I have checked my door sticker and the only code number I have see is my serie number who is F10BCDC5635 and a two lines code under the essential informations of the pick-up. this code is F0063 T0523
Old Jul 22, 2005 | 03:47 PM
LxMan1's Avatar
LxMan1
Look in the Drivers doorjam itself and not on the door. There should be a sticker with trans, axle and other codes on it. It is usually near the striker bolt.
Old Jul 22, 2005 | 10:27 PM
Mil1ion's Avatar
Mil1ion
The door plate should look like this
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Jul 23, 2005 | 07:48 PM
MBBFord's Avatar
MBBFord
Ecuri has a good idea, if you still have the tag on one of the upper housing bolts then type the #s in and we could tell you what your gear ratio is and if you have a limited slip.
