"key on" power wire
Old Jul 16, 2005 | 02:43 AM
Indy's Avatar
Indy
"key on" power wire
I justed added a fuse block under my dash and hooked the power to it to a relay. The idea was for the relay to supply power to the fuse block when the key was turned on. The only problem now is finding a suitable wire to piggyback. I don't want to tie into anything critical. What wire should I tie this into; location?, color?. The relay requires minimal power to close the contact. I will continue with my search. Thanks for any help in advance.
'05 f350 superduty
Indy
Old Jul 16, 2005 | 08:26 AM
Franklin2's Avatar
Franklin2
You could use a fuse tap, and run your relay trigger wire from the factory fuse box. A fuse tap is a piece of metal that wraps around the fuse blade and gives you a place to slip on a wire connector.
