Junk Yard Motors
Old Jul 15, 2005 | 10:45 PM
JermKline's Avatar
JermKline
Junk Yard Motors
Howdy all!
Well I'm looking for some opinions... My truck '73 F100 4x4 with a 360. In the past I have asked the question and searched the forum on coverting to a 390. Seems like a popular move. I considered the move but have another idea... Getting a rebuildable 390 from a local junk yard. Rebuild the block, then transfer my rebuilt heads (only 300 miles on them), my 4bbl intake and carb.
I called all of the local junk yards in Central Oregon and only one has (they think) a 390 (rebuildable) without manifolds for $250.00. Is a rebuildable 390 worth $250.00?
My logic here is, what if when I take the 360 apart to do a 390 conversion and I find problems. Then I'll be without a truck until I make necessary repairs. But on the other hand, if I get a 390, build it the way I want and then switch over my heads manifold, carb and other items the swap will go quicker with less down time.
Many Thanks
Jeremy
BTW: I've been looking at a set of Hedman headers and going with a dual 2.5 inch exhaust before I change to a 390. Any recommendations on mufflers? I want it to be quiet on the inside the cab. Resonance gives me a headache.
Old Jul 15, 2005 | 11:14 PM
Hypoid's Avatar
Hypoid
Ywouch!
I can pick up a short block with 30 days to get my money back for under $100. Keep shopping, might be worth a tank of gas to expand your range.
Old Jul 15, 2005 | 11:22 PM
ford390gashog's Avatar
ford390gashog
250 no way. you can get a short block here for 80.00. see if they have a location near by www.pickandpull.com
Old Jul 16, 2005 | 02:10 AM
davethecow's Avatar
davethecow
They are right,you should be able to find one for alot les then that.
I understand that in oregan its getting to be worse then cali to do any kind of modifacation to your truck?
Old Jul 16, 2005 | 10:24 AM
Ford428CJ's Avatar
Ford428CJ
JermKline
If you are close to Klamath Falls, I could help you out in that department! 2.5" inch is a good place to start. I run a 2.5" on my 76 4X4 with Flowmaster 40's. The pipes run all the way out the back! You can't hear the noise from the Flowmasters. But remember I have a 4" Lift with a 3" body Lift. So I'm nowhere close to the ground. I have noticed that cars or trucks that are close to the ground have a lot of cab noise where I don't have any at all! "JMO"
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
76 F-150 4x4 428CJ
55 FORD Truck 4-link Rides on air 428CJ
67 Stang soon to be 427
