Sponsored by: Kumho
Driving minus one lug nut
Old Jul 15, 2005 | 05:41 PM
Udink's Avatar
Udink
Would I have any problems driving with one lug nut missing from one of my rear wheels (on a '97 F-250)? I just had new tires mounted, and one of the studs was chewed up, but the tire shop said they couldn't fix it until next week. The owner of the shop told me I should be fine until then (he actually said I could drive forever on it), but I wanted a second opinion.
I'm planning on about 250 miles of mostly highway driving, plus about 40 miles on a pretty well-maintained dirt road over the weekend. Will I be ok with only 7 lug nuts holding one of my wheels on?
Old Jul 15, 2005 | 06:38 PM
triton_2002's Avatar
triton_2002
If the stud was already "chewed up", then you've probably been driving on 7 good studs for a while now. So what's a few more days? Plus I believe these wheels are "hub centric" which means most of th load is on the hub and the lug nuts just keep the wheel in place. But it really should be fixed ASAP to be on the safe side.
Old Jul 17, 2005 | 07:54 PM
goofy173's Avatar
goofy173
I drove 100,000 miles on my 82 Merc Capri with 1 lug missing of the 4.
Old Jul 17, 2005 | 09:47 PM
Udink's Avatar
Udink
For what it's worth, I drove 45 miles on rougher dirt roads that I'd expected, and about 60 miles on the pavement without any problems. But that all ended when my engine lost some power and had a serious vibration start up while doing 70 MPH on the freeway. The truck's now sitting at the Ford stealership in Orem, Utah, awating a mechanic to look at it and tell me what the damage is (what's worse, a head gasket, or timing chain/belt?). I'm a fair Subaru mechanic, but I've only owned my Power Stroke for two months, so I have no idea what could have happened.
Triton_2002, thanks for your post--I hadn't considered it, but if that stud was already stripped (which by the amount of rust on it, I'd say it certainly was), I was already running on seven good lug nuts.
truck7575
May 21, 2013 05:34 PM
AMG-SM
Dec 25, 2012 01:34 PM
Fordenthusiasts
21
May 14, 2009 04:31 PM
parochoprs
Jul 12, 2004 11:30 PM
khmorse
Feb 17, 2003 05:15 PM
