Front tire wear problem
Old Jul 15, 2005 | 05:31 PM
rangerford's Avatar
rangerford
A bit of information first, I have a 1998 Supercab 4x4 with the 3.0 when I bought the truck I had to get new Lower ball joints to pass inspection and new tires. I had the truck lined up two times at two different places. Since the I have driven about 15,000 miles and rotated the tires 3 times. The drivers front keeps wearing (feathering) on the inside. Just yesterday I noticed the if you push down on the front bumper you get a creaking noise coming from the upper control arm more specifically the upper ball joint but it could also be the bushing where the A arm connects to the frame. Also I noticed that the drivers side is a fixed arm with no adjustments, where as the passengers side has an adjustment bolt on the front and two nuts to lock down the adjustment for camber and caster. I would like to buy the whole upper assembly myself that comes with the same adjustmets but for the drivers side and adjust it to about what the passengers side is set to. Sorry this is so long any help is greatly appreciated.
Old Jul 16, 2005 | 12:23 AM
texan2004's Avatar
texan2004
Drivers side may use shims to do the adjustment. My Explorer is that way on the driver's side but the passenger side uses a bolt to adjust.
Old Jul 19, 2005 | 02:15 PM
rangerford's Avatar
rangerford
Thanks for the help texan2004 I went to Carquest today and it sounds like I am going to have to go to Ford to get one of the two pieces that I need since it is a dealer item only. The control arm that I currently have on the drivers side is OE with no camber or caster adjustments. If I get the right parts I can adjust the caster and then adjust the camber can be adjusted using shims.
Old Jul 20, 2005 | 02:39 PM
rangerford's Avatar
rangerford
More research, I was totally wrong I went to Ford and they said that the drivers side upper control arm is one unit where the passengers side is two piece. After finding this out I went back to Car Quest and bought the Drivers side upper control arm that was listed, after changing it I was sure glad that I did the ball joint was shot. Now I just need to get an alignment.
Old Jul 21, 2005 | 09:42 AM
texan2004's Avatar
texan2004
Good show. Glad you got it figured out.
keyul
Offroad & 4x4
21
Mar 19, 2015 10:01 AM
p-nut
Sep 16, 2010 06:04 PM
billj6
Oct 26, 2008 07:15 PM
vze2sgxa
Sep 17, 2008 05:28 AM
jhurd12
Jul 16, 2008 02:48 PM
