Flowmaster exhaust and headers
Old Dec 14, 2002 | 01:14 AM
1979f_100's Avatar
1979f_100
My 79 F-100 has true dual exhaust coupled with a 351M. I want to replace my mufflers with 40 series Flowmasters and headers. Is there any way for mounting this combination without having to sit the mufflers at an angle? And does anyone know where I can get headers and could reccomend any particular brand? -Thanks
Old Dec 14, 2002 | 02:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello-
You can try the <SEARCH> function in this forum and the [link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=exhaust&conf=misc|Exhaus t Systems Forum]. There are lots of posts with recommendations re sound and performance here.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 14, 2002 | 08:26 AM
todd79_351's Avatar
todd79_351
No,I had to turn mine. I have headers and delta flows. they sound so much better than my glass packs.
Old Dec 14, 2002 | 10:38 AM
LxMan1's Avatar
LxMan1
If you have the front gas tank(dual tanks), you will have to run then down the passenger side to keep the heat away from the tank. This will require hanging then sideways for clearance. I used Dynomax headers on mine. They fit great.
You may find more info in the exhaust forum though.
Jimmy
Old Dec 14, 2002 | 11:04 AM
79_250RangerLariat's Avatar
79_250RangerLariat
Might want to check the Hedman website. If you have dual tanks, and want to exit infront of the rear wheels, a set of fenderwell headers would be a good idea. Then your mufflers could lay flat and hidden.
79 250 Ranger Lariat 4wd 400 C6 3.55's 33x12.50 16.5's
78 Bronco Custom 4wd 400 C-6 3.50's 31 10.5 15's
66 Mustang Coupe Sports sprint 200 c-4 cruise o matic 3.00's
99 Grand Prix GT 230 ft/lbs torque out of a non turbo'd 6 cyl hehe
Old Dec 15, 2002 | 09:29 AM
mm79f100's Avatar
mm79f100
i put dynomax headders on my 79'f100 2w/d,and i had to cut the cross member on the pass. side so it would fit on the engine,maybe you will have better luck.if i was to do it over i would go with shorties. good luck.
Old Dec 15, 2002 | 01:52 PM
FE427TP's Avatar
FE427TP
Old Dec 16, 2002 | 02:13 PM
Dons's Avatar
Dons
I have Hooker headers on my truck and they fit great...as for the exhaust I have twin 3in threw a pair of flow masters and they need to be at a angle to clear the driveshaft...
Don
Old Dec 18, 2002 | 11:12 AM
beartracks's Avatar
beartracks
...I've been running a set of Hedman Cyclone headers for years and they are great but, I also run 10" collector extensions and they tend to run right into the tranny cross member. I planning to fab a new crossmember before redoing the muffs.
joel79ford
May 8, 2012 09:56 AM
Cluney93
Jan 26, 2010 11:53 PM
craneop
Modular V10 (6.8l)
Mar 20, 2007 07:36 AM
Josh88Ford
Exhaust Systems
Jun 10, 2006 07:44 AM
mdh627
1978 - 1996 Big Bronco
Dec 13, 2003 12:44 AM
