360 problems
Old Jul 14, 2005 | 11:29 PM
ford2008's Avatar
ford2008
360 problems
I have a 1975 ford f-250 high boy and the previous owner parked it and left it there for 16 years so i got it from him and i am fixing it up. i rebuilt the carburater and it was running good then the fuel pump went out so i got a new one and put it on and it started up. I was driving it and it died on me and wouldnt start so i took the fuel line off and had somebody crank it and no fuel came out. So i put some fuel in the carb to try to start it and it took a few trys doing this but it finally ran and it did this to me again. Does anybody know y it is?
Old Jul 14, 2005 | 11:41 PM
ford2008's Avatar
ford2008
another thing i forgot to say was that before all of this i tried to get all of the lead chips from the tank but i couldnt get all of them out
Old Jul 15, 2005 | 01:03 AM
ford390gashog's Avatar
ford390gashog
sounds like a clogged fuel filter.
Old Jul 15, 2005 | 01:04 AM
ford2008's Avatar
ford2008
do u think its the filter on the new pump i put on?
Old Jul 15, 2005 | 01:06 AM
ford2008's Avatar
ford2008
i checked the filter on the carburater and it looked fine
Old Jul 15, 2005 | 01:12 AM
ford390gashog
a f-250 should have a 390 with a 4bbl. is that what this is? first thing to do is pull the hose off where it connects to the carb then hookup a pressure gauge to the line crank it over and see if you have fuel pressure if so you know it is then in the carb. most likely a stuck valve.
Old Jul 15, 2005 | 01:18 AM
ford2008's Avatar
ford2008
ok thanks i will have to try that but it is only a 360 2bbl which i wish it wasent
Old Jul 15, 2005 | 01:24 AM
ford2008's Avatar
ford2008
if the valve is stuck would it drain the bowl because when it happened i pushed on the exelerater pump and it just pumped air
Old Jul 15, 2005 | 01:25 AM
ford390gashog
did the engine stall like it ran out of gas? or did you shut it off and now there is no fuel in the carb.
Old Jul 15, 2005 | 01:26 AM
ford390gashog
off topic, but i hope you changed the oil and filter on it before firing it up.
Old Jul 15, 2005 | 01:28 AM
ford2008's Avatar
ford2008
it stalled and wouldnt fire back up and i changed the oil and filter before firing it up
Old Jul 15, 2005 | 01:29 AM
ford390gashog
ok, do you have a pressure gauge to check the fuel pressure?
Old Jul 15, 2005 | 01:30 AM
ford390gashog
or if not put the end of the hose in a bottle and crank and see if you get flow. the motorcraft 2150 carb is prone to the needle and seat sticking, did you replace them?
Old Jul 15, 2005 | 01:32 AM
ford2008's Avatar
ford2008
ya i replaced them when i rebuilt it
Old Jul 15, 2005 | 01:35 AM
ford390gashog
ok, so what about a fuel pressure gauge? follow my above posts and let me know.
