Starting issues
Old Jul 21, 2005 | 05:21 PM
Saurian's Avatar
Saurian
I'll switch to the rear and see how it does. Sounds intriguing...if that's so it sounds like its an issue in the valve that controls the two tanks..
Old Jul 22, 2005 | 06:51 AM
low92flareside's Avatar
low92flareside
Do a search on fuel pump check valve or cross flow fuel tanks. There was a recall involving this on a lot of Ford trucks. You could probably ask at the local dealership and they'd know right away what you're talking about.
Putting in the check valve would probably stablize the pressure a little and maybe clear up some of your problems.
Saurian, ever get the filter in? Your problem sounds like a fuel delivery issue and that would be the best place to start.
Old Jul 27, 2005 | 09:04 PM
Saurian's Avatar
Saurian
I think its that check valve. If I prime it like 7-10 times, and go to start its JUST like it was normally.
Anybody have part number/internet site to buy the part, and its cost?
Also, where can I get and for how much the dual tank valve that is causing my rear tank gas to go to the front?
Where is the check valve, and the tank selector valve located respectively? Thanks guys! I'm almost positive it must be the check valve now, but we'll have to see. Napa said that couldn't find it.
Old Jul 28, 2005 | 01:30 AM
BucksTrucks's Avatar
BucksTrucks
The check valve is part of the fuel pump its self. You have to replace the whole unit. I just replaced the rear pump in my truck, and now the front gets filled so it is time to replace that.
Old Jul 28, 2005 | 09:47 AM
Saurian's Avatar
Saurian
Crap...Here I was hoping it was a part of the fuel rail or somewhere in there. That's great.
What about the dual tank selector? Where is that located?
Next question, why would the check valve not work on BOTH pumps, I mean...they're BOTH not going to burn out at the same time, are they?
Old Jul 28, 2005 | 11:16 AM
Fords4Me's Avatar
Fords4Me
For the brake lights the common problem I have found is the wire harness to the brake switch.
The wires are forced to move alot and that destroys them. Splice in a new piece of fine strand copper wire.
