Modular V10 (6.8l)
V-10 Towing Concerns, Update
Old Aug 8, 2005 | 09:21 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by GregA
Yes, but would you do it for 9%, or +40ft-lbs? From 410 ft-lbs (on my '99 E-350) to 450?
I'll make some calls manana, but I've spent the last hour scouring the Internet. Best I can figure I have a Dana 80 11.25" (or variant; 10-bolt case). I can only find references to 3.31, 3.54, 3.73, 4.10, 4.63, and 5.13 ratios. Further, it appears that the cases are different for the 3.73 and down versus the 4.10 and up, so I may have to change out the case as well. Sooo, from 3.73 to 4.10 is 9%...
Superchips claims +49 ft-lbs for ~$400...
Any recommendations for forum sponsors to contact that would know about this stuff? - GA
Uh, you have dual-rear-wheels? That's the only way to get a Dana 80, isn't it?
The Superchips claims 49ft/lbs - but at what RPM? The one I put in my 4.6L (that required 93 octane w/the chip) didn't really move the peak torque up, but put 30+ ft/lbs up past the peak, big difference in a 2-door t-bird.
And it certainly won't add 49 ft/lbs all across the range, such as a gear swap would do.
When they say "case" I don't think they mean the entire axle assembly, they just mean the differential "case" where the ring gear bolts to. You can probably get one from a junkyard in good shape (but then, you'd probably be better off getting an entire rear end, new u-bolts and bolting the thing right in
Look at this link:
http://www.precisiongear.com/dana80.htm
They show 3.73, 4.10, 4.30, etc. etc.
art k.
Old Aug 9, 2005 | 02:52 PM
GregA's Avatar
GregA
Best I can figure from calling around it appears I have a Dana 60 in the truck. So, based on your link I found:
http://www.precisiongear.com/dana60.htm
They offer a 4.30, so I guess I'll call for a price...still trying to figure out who in my area (CT) could do the work. - GA
Old Aug 9, 2005 | 03:47 PM
krewat's Avatar
krewat
Why not post in the Connecticut chapter forum?
Old Aug 9, 2005 | 04:20 PM
Monsta's Avatar
Monsta
Sit. Stay.
I do not think that you have a Dana 60 in the rear.
The E-series vans use a Sterling 10.25 full-floating rear axle.
Old Aug 9, 2005 | 04:22 PM
GregA's Avatar
GregA
Thanks, Art, I'll do that.
Another rub: after talking to a couple of guys, both noted that the 4.30 is aftermarket offroad parts versus OEM Dana (Dana offers 4.10 or 4.56). Both said the 4.30 was of lesser quality, would be noisier, and neither really recommended it, especially in vans (vans transmit noise into the cabin easier). Best price so far was right at $400 including carrier bearings. One told me I should do it myself and they'd offer all the telephone support I'd need to do the job...intriguing idea...GA
Old Aug 9, 2005 | 04:34 PM
GregA's Avatar
GregA
Ken, are you sure? I know I have a Dana, at least; "Dana" is stamped into the rear cover. I gave the guy at drivetrain.com my BOM and he called Dana to confirm; he was told it's a Dana 60... GA
Old Aug 9, 2005 | 04:42 PM
ken04's Avatar
ken04
Finally got to towing a full load with the '99 E-350 today.
Bottom line: it's better than before, but less than I was expecting. It pulls real nice off the line, good torque. As I proceed up the highway entrance ramp, though, it seems to start falling flat. If I set the cruise at 70 it'll work fine on the flats but quickly downshifts on even the slightest hill. Steeper hills (not mountains, mind you) and it requires full-throttle.
So tell me, is this the nature of the '99 engine, or should I go searching for more problems?
I have the same, in a 98. I went to LT225/75/16 because I have 3.73 gears. I have 113K, original plugs, original fuel filter. I run paper filters, no shift kit and a aftermarket muffler. My older 24' bunkhouse is like a boat anchor plus it's over 8' wide. After I get the trailer, all the gear, all the bikes and stuff I'm guessing I'm at 9K+. I have no problem around the hills and mountains around washington state, oregon and california. I have 6-14 people in the van, both a/c's blasting, both TV's on, etc. The V10 does start to run out of breath up high in the rpm range, but I've never seen it as a problem I can fix unless I replace the manifold, port the heads and get some tuned headers. The Santiam pass drops me to around 55 in second with a full load. Good luck, Ken
Old Aug 9, 2005 | 04:57 PM
GregA's Avatar
GregA
Ken, you've suggested smaller tires in the past (and I have not forgotten that). However, I thought you were talking 15" wheels, not simply 225-16s. That's a 4% reduction in circumference and makes about half the difference of going to a 4.10 rear end (and is easier to install...)
No issues with grip with the thinner tires (serious weight with the bunkhouse noted)? I assume you're pulling a tagalong? If so, what kind? I'll be pulling a 24' enclosed with not a whole lot of weight in the back of the truck, but I can shift the weight of the car in the trailer forward quite a bit...
Boy the gears are turning now (no pun intended; well, ok, pun intended)... GA
Old Aug 9, 2005 | 06:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sounds like you are more in the know than I am then. I was always under the impression that it used a Sterling axle. Sorry for the mix-up.
Old Aug 9, 2005 | 08:23 PM
krewat's Avatar
krewat
My brother-in-law recently bought a '05 E350 Superduty (yes, they call them Supertduty's now ) w/5.4L ...
It had a rear that looked nothing like my Sterling, but a HECK of a lot like the Dana 60 in the rear of my '74 highboy
I'm really going to have to check that now. I have this incredible thirst for knowledge that I got slaked here on FTE. But, I still look at things first-hand to make sure they are what I think they are.
What's the Axle code on your door sticker?
artk .
Old Aug 9, 2005 | 08:34 PM
GregA's Avatar
GregA
Mine? "C4"
- GA
Old Aug 10, 2005 | 09:01 AM
ken04's Avatar
ken04
I have E-rated tires, the weight rating is within 100 pounds of the 245's but still more than the weight capacity of the van. I pull a 24' Coachman bunkhouse conventional trailer, an older model with air, big fridge, etc. Your tongue weight should be 10-15% of the trailer weight so it's probably best to weigh your trailer with the car in it, figure what your tiongue should weigh then move the car forward or back inside to achieve the target of 15%-ish. I have a Dana 60, I just had to buy a gasket when I changed the rear-end lube.
Old Aug 10, 2005 | 11:45 AM
  #28
etcetera's Avatar
etcetera
For reference, 15's won't clear the brakes. You'll never find a set with the 8x170 bolt pattern anyways.
Eric
Old Aug 10, 2005 | 12:34 PM
  #29
krewat's Avatar
krewat
Aren't the E-series still using the tapered-nut 8-bolt classic pattern that's been used for DECADES ???
Old Aug 10, 2005 | 03:06 PM
  #30
ken04's Avatar
ken04
they (E-series) changed to the 8X170mm when the F-series did, 2000-2001 ?
