code 179 poor gas milage
Old Jul 14, 2005 | 07:45 PM
jmurphy_5's Avatar
jmurphy_5
i have 93 f150 4.9l 6. and I'm getting a code 179 i replaced o2 sensor next to cat. I cleared code and it came back. i noticed that my air filter was clogged so i changed that. could that cause this problem? also lost about 50 mile per tank of gas. any ony have any tips?
thanks.
Old Jul 14, 2005 | 08:13 PM
mecambello's Avatar
mecambello
Did you clear the codes after you replaced the air filter? What model and year truck?
Old Jul 14, 2005 | 08:17 PM
93nighthawk's Avatar
93nighthawk
Clear codes, and replace the fuel filter. That will help millage some.
jmurphy_5's Avatar
jmurphy_5
i have 1993 f150 with the 4.9l 6 and yes but i hav'nt hab a chance to drive it to see if it comes back on.
Old Jul 14, 2005 | 08:39 PM
MemOrex's Avatar
MemOrex
179 is rich code...and you lost 50miles you say, so Im betting your O2 sensor was just doing its job(setting RICH) and needed no replacement.
Some things to check:
-High Fuel pressure (most common problem)
*Check it at the fuel rail valve...on the I6, the pressure should be 55PSI at idle.
-Leaking Injectors
*See how fast the fuel pressure bleed down is.
-O2 sensor stuck in LEAN mode.
*Replace O2 sensor
Old Jul 16, 2005 | 09:08 PM
jmurphy_5's Avatar
jmurphy_5
i dont have tools to check pressure but a trip to autozone should fix that. thanks for tips i'll let you know results.
ol_red92
Jan 26, 2015 10:18 AM
jgunter1
Mar 21, 2011 09:53 AM
Boss F150
Jul 5, 2009 09:23 AM
tome
Jan 20, 2004 08:35 PM
94156
May 23, 2003 02:45 PM
