Sponsored by: Auxito
P0181 Code
Old Jul 14, 2005 | 06:54 PM
cdawley1's Avatar
cdawley1
P0181 Code
Hi,
I have a 99 F-150 V6 that the Engine Light came on. It came on while I left work. I rode all the way to my parents house which is about 45 minutes away to diagnose it. It came up as a P0181. I then came home and looked in my Ford manual and it wasn't listed. I don't even know where the Fuel Temperature Signal sensor is. I replaced my PCV valve and hose last week when the P0171 code came on. That fixed the code until today. Not sure what else it could be.
Thanks,
Chris
Old Jul 14, 2005 | 11:12 PM
Racerguy's Avatar
Racerguy
Unless your truck is different than the ones I've seen you shouldn't have a fuel temperature sensor.
Are you positive that it was a P0181 and not a 171 again?
Old Jul 16, 2005 | 01:39 PM
cdawley1's Avatar
cdawley1
Yes. The engine light just came on again today and spit out a P0171 code. I am not sure what else I can try. I tried to test the oxygen sensor but can't find a way to test it. If anyone has any suggestions, please let me know.
Thanks,
Chris
Old Jul 17, 2005 | 12:29 PM
LxMan1's Avatar
LxMan1
Try cleaning the MAF.
Old Jul 18, 2005 | 09:45 PM
jghaviland's Avatar
jghaviland
My book discribes P0171 as "System too Lean (Bank 1)", thus the MAF is good advice.
Old Jul 18, 2005 | 09:49 PM
jghaviland's Avatar
jghaviland
I was very frustrated the other day with my truck and went and bought a OBDII code reader for $100. I had a DPFS code 1405. Between my ford book and the code reader I was actually able to fix the problem. I estimated that I saved $300 over having the dealer work on the problem. ($98 for the sensor, $5 for the hose and $100 for the code reader, and 30 minutes of my time.)
Old Aug 24, 2005 | 04:30 AM
rgrayson's Avatar
rgrayson
Smile P0171
Thanks,
Chris
I had codes P0171 and P0174 with rough idle on my 98 Expedition. I checked the DPFE sensor and sure enough it was clogged with white powdery deposits. A new sensor for $51 at Auto Zone should fix the problem. It did on our 97 Explorer which had a code relating to EGR function. The metallic sensors are a piece of "....". The replacemet ones are plastic, they won't corrode. Good luck.
Adam0181
2004 - 2008 F150
Aug 13, 2016 11:09 AM
Jefff H
6.7L Power Stroke Diesel
Sep 10, 2015 02:29 PM
53crewchief
Sep 9, 2012 01:20 PM
randinow
Jan 8, 2010 11:09 PM
msanders
Feb 25, 2005 03:26 PM
